TwilightAudio
Previously known as shieldwriosto
------ These were my initial impressions. I will not edit them out as I think it shows how small mistakes can make massive differences and completely ruin someone's experience. My updated review after finding and fixing the issue that caused the impression below is posted as a response to the thread. Here is a link to the revision: https://www.head-fi.org/threads/kz-...d-to-rival-nothing.905995/#post-14945138-----
If I were to judge on build quality alone I’d give this 7 stars. For the money this level of fit and finish is absolutely astounding. Too bad then, that they sound as poor as they do. This is my first foray into super budget iems from China.
Given the solid performance we get in EarPods, or any of the other earphones thrown into phone boxes from lg, Samsung, and one plus, I was expecting at the very least to get something that rivalled those. Nope.
The ZS 10 Pro has a fairly strong bass response. Treble is also decent if a bit on the tinny side. But the mids. Did KZ try to design this IEM to remove vocals from tracks? Everything in the mids region is so recessed you could very easily mistake them as ambient sound instead of part of the track. There is also the question of the awful imaging. While the soundstage is wide, sound appears to only come from one of 3 spots. Dead center, far left, or far right. Also the balance is off as the right sounds significantly closer than the left. This I felt in my music but I had to use some simple channel testing tones to make sure. Of course I double checked with my gr07 to make sure it wasn’t my hearing that was causing this effect.
If you asked me to recommend something under $75 I would recommend hunting for a thrown away pair of phone bundle earphones, or something like the $5 vemonk before I recommend this. Given the price though you could buy them just to jazz up your collection from a visual standpoint. Just don’t ever plug em in.
