Prakhar
- Jan 3, 2012
Obviously I wont be able to buy the ZO2.1 so do the q40 still sound better with the Zo 2.3?
I think reloop has a new model called the rhp-20... Any chance you could check it out?
Attention fellow bassheads, here's an interesting pair of rather new headphones (entered the market at around November last year) no1 seems to know anything about, any1 willing to do the community a favor?
http://www.reloop.com/reloop-rhp-20
Appearently it's bassheavy from a few comments scattered around the net and they appearently seems to not be too bad, youtube users are very questionable but one person thought it sounded a little better than Pioneer HDJ-2000 that most agree are slightly overpriced sound wise. Otherwise they are circumaural design with memory foam pads so comfort should be excellent and at least hinges or the area around it is made of aluminium (but I suspect hybrid metal/plastic design but yea who knows) and the headband of hard rubber so they should be rather durable too. Also comes with detachable cord but it's using mini-XLR connectors to the headphones so it's a bit unusual.
The street price varies a bit but cheapest seems to be around 160~$170 or so maybe which looks very reasonable if it delivers on the SQ front too. It seems to be quite new in the market, who knows, it could be a hidden gem. ;p
TECHNICAL DATA
- Frequency range: 3 Hz - 30 kHz
- Acoustic pressure: 110 dB
- Impedance: 25 ohms
- Connections: 3.5/6.3 mm jack (gold-plated contacts)
- Cord: 3 m (spiral cable)
- Weight: 270 g
- Incl. high-quality carrying bag
I know specs aren't usually the most accurate but holy **** 3 Hz haha, that's same as for Sony XB700. Otherwise 110dB sensitivity and 25 ohms impedance is quite striking too, these should be easy driven.
FEATURES
- Professional DJ headphones, closed rotary and retractable construction
- Convenient rotary mechanism for easy monitoring via one ear cup
- Powerful sound for clear frequency separation, optimized for DJs
- Comfortable Memory-Foam paddings with finest protein-leather surface
- Large cavity for comfortable, closed wear
- Parts of the elements with rubber-paint finish
- High-quality headband made of robust hard rubber
- Solid rotatable and foldable mechanism made of aluminium for maximum steadiness
- Flat Comfort construction: Compact and light ear cup chassis
- One-sided cable duct with removable mini XLR plug for unproblematic changing of cord
- Extremely high output rating
- Extremely robust construction for DJs' continuous operation
- Elaborate and stylish deluxe headphones
