Here is a side-by-side comparison between ED12 and ZS3. ED12 spots the glossy look as the ZS3 glossy version.
[COLOR=FF4400]![](https://www.head-fi.org/attachments/1709381/)
[/COLOR]
Ok after checking with the seller, the explanation is that
Mic version - Red on Right
non Mic version (what i'm using) - Red on Left.
So that was the reason i was spending so much time trying to figure out whether i plug in the pin wrongly.
Here is my impressions after running through a few songs.
Quick face off
new ED12 vs reigning Champion ZS3.
Summary/Overall impressions
Similar to ZS3, the earphone reacts very well with High resolution audio such as FLAC and other lossless format. Sound is average at lossy source.
Physically, the ED12 uses the same rubbery cable as the ATE which to me is fine. Similar to the ATE, ED12 also does not come with memory wire, thus the seller also sent a pair of Ear Hook with the ED12. Initially i was not comfortable with the default silicon tips that came by default, thus i swap it by using the ATE ones and well how good it fitted.
Tested Track - Silent Shout (FLAC)/Hey Eugene (FLAC)
Treble
The ED12 is more forward with the vocals and also brighter. Suspect fatigue will set in faster as compared to ZS3.
ZS3 sounds smoother comparatively.
The ED12 says 'do you understand what i am saying!', while the ZS3 says 'i'm telling you this is what i mean.'
Mid Range
No significant difference i can pick out here.
Bass
The ED12 is more controlled as compared to ZS3, which to a small group of users the ZS3 bass can be overwhelming at times. The ZS3 says 'set me free', while the ED12 is set loose but with a lease on.
