So my CRA just arrived. Because everyone review them already so i just gonna do a quick impression
Non Sound:
Box seems smaller compare to older kz. Tips is actually unusable, they aren't starlight, just ordinary tips that you can find everywhere on amazon, stiff and make CRA sound worse. Copper cable like EDC, not bad but i kinda want silver cable like NRA.
Sound:
Stock tips: V shape
- Bass: Subbass focus, very very tight and fast, detail, there is a lot of bass with just tiny bass bleed. Actually too much bass for my liking
- Mid: clean and neutral, a little bit lean if you come from harman iem but very clean vocal, female vocal sounds better than male vocal (whispy, clean)
- Treble: Well extended, even better than my Heart Mirror. 5k peak hits sometimes but overall not too much
Kz smol tips: Balanced
- Bass dial down a little bit make it more suitable for my taste
- Mid remain the same
- 5k peak is fixed
Timbre is the same as DQ6, just 1 cleaner and 1 more analogue
Absolute rec for under 50$, nothing beat this
