What the heck is this??
http://www.aliexpress.com/item/Original-KZ-ATE-Sport-in-Ear-Earphone-With-Microphone-3-5mm-HIFI-Metal-Stereo-Earphones-Super/32405730615.html
I sold my Flare R2a, they simply weren't cutting it. Got my Kickstarter money back, Huzzah!!! Boy would I have been PISSED if I had bought them now for $270 after Kickstarter.
Okay now Back to KZ, WHO Recommended the KZ Micro Rings? One ATTABOY!!! These things are Amazing. Vocals are OUTSTANDING regardless of Price. Some of the Best I've heard from ANY earphone. The whole presentation is World Class. These can Easily be my KZ Favorites, I heartily recommend getting these if you can. Tough to fit tips to though, but I have a trick.
Okay now Back to KZ, [COLOR=00FF00]WHO[/COLOR][COLOR=00FF00][/COLOR] [COLOR=000000]Recommended the KZ Micro Rings? One ATTABOY!!! These things are Amazing.
Many Thanx Scrambler. I couldn't remember who told me about them and I was just too friggin' lazy to go back and read through 20 or 30 Pages to find out.
Well, I'm a Micro Ring fanboy so I had to recommend them .
My intro to them was horrible however. They came with useless tips; small and large were for an iem with a normal nozzle, and the mediums were torn. The left housing wasn't glued together. I briefly listened to them on first opening then tossed them aside for the EDse.
Once I got over the initial disappointment, glued them back together and found a good set of tips, they have been one of my favorite iems.
They isolate quite well with Foams, I counldn't hear a thing.... The trick is You have to find Foams without the inserts. Even the Largest comply 500 is too small to fit over the nozzles. I have some of these coming:
Should look cool as hell with the Black and Blue Micro Rings. I'm temporarily using a pair of Black Foams that came with some other KZ Earphones, although it was a bit of a stretch...
Ok I want to try my hand at KZ again after my ED9 broke, I have a very warm amp, the E07k, that makes some headphones sound boomy, should I get the ED9 or ATE?
My defective brass ED9 sounded tinny, like there simply wasn't a natural amount of mid bass and especially sub bass even with my amp.
Why are there 2 threads?
For non fatiguing, smooth sound with slightly better timbre go for ATE. For flexibility, neutral - ish sound go for ED9. Both pair up very well with warm sources.
Both lack sub bass though... ED10 excels in that region. But with warm source it's a no no.
You shouldn't get another ED9 if you didn't like your previous ED9 (when it still worked). I also have the ED9 and agree that it's VERY bass light. After getting used to the ED9 it made my K10U sound very boomy.
Maybe the ATE will suit you more. It has been described by many people as balanced, natural and smooth, but both EISENbricher and I think it lacks sub-bass.
In my ed9s the tiny holes in the nozzles were not completely closed while I think they should have been that. Pushing a bit with a tooth stick against the plastic thing covering the hole made them sound 100000x better.
I thought they were defective without doing that.
