Thank you very much
I ordered a cable.
I ordered a cable.
Do you have AS10 to compare with? They share the same drivers. BA10 are definitely tighter.Just arrived: BA10. After a quick listen I can pronounce these as the best KZ I have tried so far. I prefer them to the ZSX and even the ZS7, which they resemble except the BA10 sounds tighter. No fit issues, either as I have large ear canals. They sound softer than expected, nothing like A10 or C16 and are more similar to TRN BA5, but the sub bass is massive! Thanks, Podster, for recommending these!
Speak about the devil, after months of radiosilence, KZ are coming up with a new TWS KZ S2:
https://www.indiegogo.com/projects/kz-s2-next-generation-hybrid-tws-in-ear-monitors/coming_soon
https://www.linsoul.com/pages/kz-s2
For those that bought their recent wireless gear, I read there were connectivity problems? Hopefully it is fixed with this.
I was interested in buying the AS16 but they are still so expensive. I have the AS10 but never tried the BA10 due to the shape of it.
I would wait on feedback for the KZ S2 before ordering them.
No, I do not have the AS10. The ZS7 shares the same mid and treble BAs and the BA10 sounds similar but the bass BA is superb, better than the TRR BA5 or any CCA model I have.IDo you have AS10 to compare with? They share the same drivers. BA10 are definitely tighter.
I now largely listen to AS16, I gradually learned to enjoy the elevated treble, and they do everything for me at the moment - brilliant with string quartets.
ZS10 PRO are more wild and cheerful. I once listened to electric guitars like I've never heard them before, an amazing experience. Those "steely" 30095s can work like nothing elseNot sure if I wanna take the plunge in the ZSX. I'm loving my ZS10 PRO so much, I'm not sure i can justify getting this set. With the music i listen to, i cant justify spending more. ZS10 PRO is my current favorite.
Yup, I concur. I enjoy alot of older 70's to 90's rock, as well as late 70's-80's dance and funk. Even a bit of pop from that era also. Can't say I can detect any "steeliness" with the material I mostly listen to. Then again, I don't often listen to much acoustic or anything with much higher stringed instruments like violin, etc. ZS10 PRO is still my favorite set, with TFZ NO.3 a close second for more dance oriented music.ZS10 PRO are more wild and cheerful. I once listened to electric guitars like I've never heard them before, an amazing experience. Those "steely" 30095s can work like nothing else
(For acoustic music I prefer ZSX to ZS10p, while favouring AS16 and AS12 (with treble filters removed) over ZSX).
So your answer would largely depend on your listening preferences.
Clearly not many people here really spend that much time listening to their kz iems.Can't stand when people repeatedly talk about ZS10 pro = automatically = steely timbre.
I played violin for last 30 years and one thing I can tell you is that ZS10 PRO's timbre for classical music is not that bad.
Violin E strings use steel or plated steel strings F F S. It sounds amazingly accurate compared to my other way more expensive BA sets.
