Kingsound M03 - Can it drive Stax?
- Thread starter nvfan
alexdemaet
Is it common when using esl devices that you hear a small distortion when there is no music is playing? I hear like a very silent buzzzzzz when pausing the music. I used to hear this buzz also when I switched from esl to dynamic headphones on the iFi IESL
duribe
Hey new to audio here, Would the stax sr-003 mk2 go well with the kingsound m-03?
alexdemaet
I have tried the Kingsound M-03 for my IEM. Unfortunately, there is a flute sound when I connect a dynamic/eim headphone on the 3.5mm headphone output. I have asked the support about this and they say that this is very common.
timb5881
- Apr 17, 2006
I have done this and it works well. Only downside is weight and size. I have a srm002 which only can be used with the SR-001/002mk2, and it is much more portable.Just a comment, you can easily transform srm252 into a portable device (as I did) by buying a 12V battery using a correct plug. Add. benefit there is no residual ac noise.
