HemiSam
- Jun 9, 2014
Sure looks like you need to do some reading of your own and likely some trial listening.
HS
HS
[[/S] also some folks have clearly preferred 009s after my question, if 007mk1 is a better choice then i will buy it instead.
Alright after a lot of hearing/reading opinions, i will sell my kidney and buy both 009 and 007s with carbon and gungnir multibit.Will do review too if you guys are interested and images and video will be included so that no one calls me a liar without a reason.
You must have some personal demos with music you are familiar with. Opinions on here will give you paths to take, but the decision in the end is a personal thing.
Also remember there are those that claim the 007 is best, others the 009, others the Abyss or HE-2K. It is not about fact, it is about your own trails and your own ears ultimately.
It is INSANE to buy a BHSE/Carbon/009 without hearing it at a buddies house, a dealers or a hifi show at the very least.
It is also INSANE to state forever some person said the 007 is better than the 009 (won't say who in that case). those quotes are that persons opinion, with their DAC and their personal idea of what they prefer. Even the type of music comes into this as well.
So, get out there, listen to some gear, the ones you have been told about. Then after some soul searching, buy something. Music is like a love affair, just because person A is like person B doesn't mean they will get go together perfectly and get married or even be happy.....
My advice unless you can afford a 2K DAC at least (huge generalisation but you get my point) you need to get the 007s. It is easier to system match and will not create as many 'issues' The 009 is the best IMO but it needs work to get there.
. I will do a vs comparison. So it may help others too, i had a hd 800S like i said before, and 009s should be much warmer and smoother in comparison while 800S were harsh and too thin, .I am generally into bright headphones and i listen to classical music a lot, so don't worry.
I agree with everything this man says. The 009 may be too bright for you, 007 may be too dark, it really depends on the rest of your system, perhaps even down to cabling. One this is for sure though is that I would not recommend 009/007/Carbon/BSHE with anyone who would not spend at least $2000 on DAC, and even then, the DAC will still be the weakest link in the system. You'll easily hear it too as the 009 (or even 007) will easily reveal how not on par your source is.
For headphones that sound extremely organic and lifelike like with what electrostatics provide, I would recommend an R2R Ladder/NOS DAC.
Either a Holo Audio Spring for $1500, or a used Metrum Menuet for $1800-2000. For around that much you can also obtain a used Yggdrasil. But to be real honest, for a setup like the 009/Carbon, I would at least spend $5000 equilvalent for a DAC to really let it shine. Like a Metrum Pavane or MSB Analog DAC.
Smoother yes, but not warmer. I abandoned my HD800S/GS-X MKII setup for a 009/Carbon a month ago.. If the 009 had more bass than the HD800S, I would have been done with this hobby. Even the darker 007, no matter what revision still is not as warm as the HD800S.. While I agree the HD800S to be somewhat thin sounding compared to other dynamic headphones, it still has more body and bass impact than the 009. The 009 may be fuller sounding due to its better tonality, but electrostatic bass just isn't on the same level as planar magnetic or dynamic drivers, I hope you know that.
It becomes subjective at this point. You say you like bright headphones but deem the HD800S harsh and thin. While I do agree that it can be somewhat thin and harsh in the treble, comparing to the 009, some would find the STAX to be thin.
