I see the hiby fc4 mentioned in this thread. I'm auditioning the fc4 and the KA13 and can't decide which one I should keep. The price difference I paid was $7 so negligible. Both are updated to latest fw. fc4 has MQA but I disable it anyway so I can EQ.
On paper, the KA13 seems better. Newer, higher output, and fiio I think has better reputation over all. OTOH, audiosciencereview measured the fc4 and crapped all over it. The IMD is bad and the power rating is false advertisement, they said.
I'm using them with an Ananda stealth and power isn't an issue on either. Plenty of volume and plenty to spare.
It seems to me the KA13 sound is 'cleaner', more resolving, if DACs can be said to be more resolving. I can hear what I think is distortion at times on the fc4.
Yet I can't escape the feeling the fc4 sounds better. Fuller, more musically pleasing, less digital? Even if sometimes it sounds muddy.
Maybe b/c the Ananda is already pretty bright and clinical, so it's too much when coupled with the KA13. The fc4 takes the edge off, warp and all.
If you have both, please advise. Feel free to weigh in even if you don't
And so does FC6. That said, specs are measured until the distortion level passes certain levels rather than until failure, so for a more coloured DAC/amp, it may hit the distortion level limit earlier than the actual power output. I think Hiby often under-reports their power since they may have chosen stricter THD tolerance, but Fiio chose a more generous 1% for KA13 measurements.
Hiby FC4:
Fiio KA13:
Not to say that Fiio is somehow worse for selecting a looser parameters (human ears rarely can catch anything below 1% THD+N anyway. Besides, music is just distortions that sound good.
Also, the loudness is only one part of the driving characteristics, there's also dynamic range and other technical abilities that the gear can maintain at that volume level. That's why I always take the specs as just general guidance and still trust my own ears for evaluating a gear.
Both KA13 and FC4 are excellent dongles, I can very easily recommend it to other people.
Just saw ther KA17 came out. Instantly returned my KA13 to Amazon and ordered the KA17. I was so torn between the 550mw of the KA13 and the play/pause button of the KA5. Eventually went with the extra power of the KA13. Now KA17 is available it's a no brainer. It looks absolutely perfect, the only unanswered question I have is if the USBc power input has passthrough to also charge your phone as well as powering the dongle. I 99% suspect it doesn't but that's a small price to pay for what looks like literally a perfect device - highest power output available, usbc power, top of the line dacs and amps, play pause button, desktop mode, display, SPIDIF out and with included leather case?! YES! I would love to see how this sounds compared to a dedicated DAP and a high quality desktop amp.
I will be using this on my desktop in spidif out to line in to my SMSL DO400, and as main portable hifi dap with S23 Ultra. Thanks FIIO!
@FiiO hey, have you guys tested your portable dacs with Pixel 8 pro phones.
I own a KA3, btr7, tanchjim space, moondrop dawn and one ddhifi dac. They all dont work with Pixel 8 phones.
I lost my KA3, so i haven't tried that one, but the rest of them make static noise on the left channel when plugged in. I tried posting in Pixel 8 support forums but they say that i should contact dac manufacturers. I want to buy a wired Fiio Dac, because i have had good experience with products from Fiio.
I have been researching and it seem like Pixel 8 just support some dacs and not all of them. Seen alot of threads regarding that on reddit.
Would be awesome if we knew which dacs work with newest Pixel and which dont. Thank you in advance.
