NascarGene
A little follow up on my experience with my CSX 5's ... I got my 2nd set of UE's in early September, after getting approved to have them redone with professional molds. I continue to love them - I wear them a few times a week to listen to music, watch movies/videos, etc. I fly a lot for work and they are amazing when flying. The natural noise suppression is incredible. I "test" the noise suppression on most flights, and I have no plans to stop using them when flying. Along similar lines, I've stopped using my over the ear "racing" headphones that I wear while riding my lawn tractor and also use when I attend NASCAR (and other) races. At the races, I hook a scanner into my headset to listen to drivers, the radio and TV broadcast - it's a great way for us to get more insight at a race. The UE's blow away the clarity and noise suppression I get with the headset -- which is a mid-range headset with both scanner input and a microphone that connects to a wireless radio.
I've been mostly pleased with the performance from the bluetooth cable, and the attached battery. I can usually get the hours of usage I'm looking for.
My one recurring problem is the wired cable. I've requested 2 replacement cables already as I've had two of them break at the end of the connector on my right ear. I follow the recommendations for use and storage - when using the cable, I loop it over my ear. When separating from the IEM, I take care to use 2 fingers to provide pressure against the IEM and pull on the connector - not the cable, and when storing I loosely wrap them around 3 fingers and then store the cable in the case.
I'm thinking about adding some heat shrink tubing over the connector end and down about an inch to try to give this part of the cable more strength.
Has anyone else had issues with the wired cable? I've had success with getting 2 replacement cables sent out, but I am sure that UE is not going to keep supplying me with a $100 retail cable for free.
