A few things to try:
. Different USB port. Try USB view, a windows program, that let you see whether your DAC is on the same hub (motherboard has hub too) as other devices, and let it on a port that is not shared.
. DPC latency issue: Download DPC latency checker (a google should show you the site) and check whether you have any red column. If so try their recommendation by turning off each HW devices, like network controller, until you find the culprit, either try updating its driver or remove the device if you don't need it. Sometimes software can cause this issue, too. Examples are craps installed by HP, Kaspersky, Norton use Microsoft Security Essential Instead, it's free and enough to secure your system.
. Lacking power for your HRT, this is a known issue as far as I have read. In this case you have to again try different USB port, RMA your PSU. Prebuilt system is well known to have just good enough power supply that turns into not good enough in some cases. Another way is to try a powered hub.
