AnA1995
- Jun 9, 2009
Originally Posted by fran /img/forum/go_quote.gif All circuit grounds should come together at one point. All PS grounds come together at another point - usually just at the main PS caps. Then using heavy gauge copper connect circuit ground point to PS ground point. Now you ahve 2 "star" grounds connected together. Lastly make up a circuit breaker for connection to chassis (safety) ground: Wire 2 regular diodes 69 style ie back to back. Solder in a 15R 5W resistor in parallel with the 2 diodes. Lastly solder in a 0.01uF cap also in parallel with diodes. Connect ground point at PS caps to chassis through this. Once you get that sorted out, then come back to us if you still have a problem Good luck!! Fran |
- Your PS must able to put out at least 0.65A at 24V, over 1A recommended. |
- If I redo mine, I will use quality multi turn trimmer. Cheap ceramic trimmer I had on mine makes crackling sound whenever I turn it, and its hard to adjust. |
- Blue LED is high intensity type, Red LED is standard type. Make sure you don't use high intensity type Red LED. |
Originally Posted by FallenAngel /img/forum/go_quote.gif 3A @ 24V?! Are you using a cheap switching supply? I definitely recommend going with a half-decent transformer in a box, not switching supply, they're about $10-$15 usually. |
