rickcr42
Are YOU talkin' to me?
- Jun 21, 2001
for an alternate take check out the speaker/headphone junction box here :
http://www.avahifi.com/root/audio_ba...pdf/ab1987.pdf
Not too big at 281K but right click and "save as" is probably best.
This is how i configure my boxes that have headphone resitor matching networks but I take it a step further by making one headphone output and switch optimised for high Z cans and the other uses the above Joe Grado resisitor matrix.
Another thing it is my habit to do is to switch in the headphone matrix THEN switch off the speakers so the amp always "sees" a load at its output.
Some amps do not take kindly to having a no load situation and have been known to self destruct,especially some tube amps.
The fix is not easy and not cheap so i take no chances and the additional load in parallel with the speaker load will do ZERO harm.A nice thing if you are running extension speakers in another room for someone else and want to listen to headphones locally.
so my "box" is a set of four toggles :
Toggle Switch 1-speaker A
Toggle Switch 2-speaker B (in my case goes to my "dynaquad" style Hafler QD-1 MKll passive surround system)
Toggle Switch 3-high impedance cans
Toggle Switch 4-low impedance cans
Gadgetised and assessorised Rick
[size=medium]BAN THE SPRINGCLIP !!!!!!!!!!![/size]
