- Jun 26, 2001
If you're going for an all out, no holds barred op-amp setup... its gotta be two OPA637s... they're about £18 each from RS... and whatever adapter you'd need to get two mono chips to work in stereo
Originally posted by Duncan If you're going for an all out, no holds barred op-amp setup... its gotta be two OPA637s... they're about £18 each from RS... and whatever adapter you'd need to get two mono chips to work in stereo |
Originally posted by eddy Lucky for me I stumbled across this thread as I am planning on ordering a Chiarra kit on monday (assuming I get paid on time). Its either that or an IPL Transmission Line speaker kit. Think I will go with the Chiarra now (theres allways next month for the speakers). Just a couple of quick questions... 1) I am currently driving a set of grado SR-80's from the headphone stage on my Rotel RA-930BX integrated amp. Would it be safe to assume that the Chiarra would provide a sensible upgrade? Not that it would put me off if it only sounded a little better as I have been wanting to try my hand at building a dedicated headphone amp for some time. 2) I haven't built any electronics projects since university but I have moderate soldering skills, a fair understanding of basic electronic theory (if rather rusty) and can tell a capacitor from a resistor. Would this project be within the scope of my somewhat limited skills (assuming I take the time to read the documentation properly)? Anyway, sweet looking amp. Thanks for the pics and review. Thanks for your time. Regards ed |
Hi Ed, The kit is very easy to build but the instructions, in places, could be better. Luckily Shaun Williams will help with any bits of the instructions that don't, at first, make sense or alternately you could e-mail me if your stuck on any part of it. Basically it is just a case of soldering the components into the correct positions on the board and I'm sure you'll manage it if you are good at soldering. The Chiarra will knock the socks of the Rotels headphone out stage and by quite some considerable margin. Be prepared for a long burn in with the amp though... it really doesn't kick into gear until it has 200 hours + under the bonnet, after the initial burn in period it really starts to sing. Buy this kit and you certainly will not be disappointed. All the best. Mike. |
Originally posted by eddy Hi Mike, Thanks for the comments, just what I wanted to know. I am especially pleased to hear that the Chiarra will provide a worthy upgrade over my Rotel. I will be ordering the kits on Monday if I get a spare minute. On a related note I wonder if you could find the time to answer a couple more quick questions.... 1) Did you order online? If so did the process go smoothly? 2) How long did it take for the kits to arrive (roughly)? Thanks again for your help (and to Nisbeth, much appreciated). Regards ed |
Originally posted by eddy Hi Mike, I went ahead and ordered the amp, psu and some other bits and pieces last night using the online ordering system. Seemed to go smoothly but haven't received any email confirmation yet (although I didn't really expect to as it was out of hours). 10 days sounds more than reasonable, I really just wanted some frame of reference to stop me getting impatient. Any tips/tweaks you have to aid construction or avoid potential disaster would be greatly appreciated. Thanks again. Regards ed |
Hi Ed, I'm certain Shaun will confirm your order very soon and there is no need to worry. I'm going to build a kit for a fellow Head-fi member and he ordered it about 10 days ago. it's due to be sent tomorrow so I'd reckon on between 7 - 10 days for it to arrive before getting impatient The kit is pretty easy to build and the instructions are not bad but they do have their moments where you wonder what they are referring to but, on the whole, they are very good. If you run into bits you are not sure of then feel free to e-mail me and I'll help you out. The most confusing part was with the 14 zero ohm resistors.... the manual says "fit a total of 14 zero ohm resistors in the component positions marked with a straight line" you will notice that there are only 12 component positions marked with a straight line leaving you with 2 spare resistors. These link across the two "A" component positions. The markings are A B A B fit them across the 2 "A" positions. Apart from that it is pretty plain sailing. All the best. Mike. |
