Jie Extreme Player 2.7.2 released
Dec 28, 2012 at 4:54 AM Post #32 of 246
I have been listening to 2.4.4 and can say that it is a definite improvement, somehow even more tonal density, impact, timing precision and focus, finer detail and microdynamics and even less grain.  This is still by far my favourite audio player.  Well worth converting your music library to WAV
Dec 28, 2012 at 6:29 PM Post #33 of 246
I wonder if someone could write a little .exe application that would
a. allow a flac file to be right clicked on in Windows Explorer and
b. decompressed to .wav loaded into RAM
c. launch Jie to play the .wav out of RAM
Is that possible?
It would give the advantage of Jie being unmodified so it still sounds great with a  convenience bonus.
Dec 29, 2012 at 6:07 AM Post #36 of 246
I'm running the latest JEP, 2.4.4 (AVX), on a dedicated audio PC and it sounds better than any other audio player for Windows - and I've tried them all and keep track of updates. Jie Extreme Player is brilliant. I only have one problem: the latest JEP will miss certain tracks when I'm playing a full album, and I can't work out why. Is this a bug? Thanks again from a grateful user.
Dec 29, 2012 at 6:58 AM Post #37 of 246
JEP can only support standard WAV files and cannot contain other tags.
JEP does not use the Windows API to parse wav file.
To ensure high quality sound output, JEP compatibility make it bad, sorry.
Dec 29, 2012 at 2:58 PM Post #39 of 246
Why can't you have it unzip the FLAC files just before playback? cPlay does this. Also how does this compare to cPlay because I feel that is the best sounding player so far.
Dec 29, 2012 at 4:37 PM Post #40 of 246
Thanks for the reply. But what exactly is the 'standard' WAV file? Does is contain any kind of tag?
I've tried clearing all tags using dbPoweramp. I've also renamed individual files starting with the track number (01, 02, 03 etc).
But I'm still experiencing this problem.
Dec 29, 2012 at 8:43 PM Post #43 of 246
Do other players play these files in order under event mode WASAPI - I found my DDC driver to be the culprit in my inability to play certain files.  I also found that buffer length seemed to influence the stability of my DDC under WASAPI event mode and ability to playback files.  Never drivers for me were much more tolerant.  I hope you sort out the issue as 2.4.4 is as close to perfect a music player I have ever heard.
That said I seem to prefer the sound with the less compatible DDC drivers, I think drivers walk a fine line between buffer compatibility and optimal performance.
Dec 30, 2012 at 6:04 AM Post #45 of 246
And I've finally found the cause of the bug, ThinkSpace. It was the AudioServiceTSOP you offered on an earlier post. I deleted these six files from System32 and replaced them with the original W8 ones...No more problems. JEP 2.4.4 is obviously not compatible with that optimisation pack.
Luckily this is not a drawback, because with this latest JEP version, I find that sound quality is much better with the original W8 audio files anyway.
To anyone wishing to improve their audio PC setup: make a donation to ThinkSpace and get the latest JEP.
You won't be sorry.
