JH Audio Lola Impressions and Discussions
Feb 23, 2021 at 2:41 PM Post #707 of 739
When looking the graph, the gap between the peaks and deeps are not much different, until it gets to 7k+, with that boost. So it will rather be a balanced signature from low to high mids. That deep will most likely bring the vocal forward in the mix as some of the singers can sing around 4-6kz.
Let me know your thoughts.
That was definitely something that came up with the treble at 7k+ possibly with harmonics.
Another consideration was the bass being more balanced, causing the dip to not be as evident in comparison to Layla
@riverground here's your chance to chime in with any additional thoughs
Feb 23, 2021 at 2:44 PM Post #708 of 739
The harmonics definitely helped it in that regard as well.
And as for the bass being more sub-bass focused taking away the mid-bass bias the Layla had most likely gave more isolation for the upper-midrange to shine through.
Feb 23, 2021 at 4:43 PM Post #709 of 739
Yeah, clearly the focus is on 5k onwards. it's like everything sit on a single line on the stage and those frequencies sits a few steps forward in the mix. a bit of sub-low to avoid mixing with low-mids.
Feb 24, 2021 at 12:49 AM Post #710 of 739
Unit variance is a thing, even though not as bad as some other brands. I've owned multiple pairs of Rox/Lola/Layla and auditioned many more. They all sound different here and there, but the general trend is consistent.
- Roxanne is the darkest. Has a forward lower-mids that many dislike, although I find it enjoyable.
- Lola is the brightest. When the treble is eq'ed down, Lola is probably my favorite JH. The treble really gets into the way of that beautiful DD midrange.
- Layla is somewhere in the middle, which is not necessarily a good thing if you know what you want. Lower-mids is still thick compared to other brands.
- The performance series resolves better than FMJ series and the original carbon fiber series. Like a tier better. Haven't tried the aion series though.
Mar 1, 2021 at 5:09 PM Post #711 of 739
In January I received my pair of custom Lolas. I've been enjoying them with the Hugo2. It is a wonderful combination!
If I may ask, that thingie with JH logo on it is the box for your CIEMs, isn't it?
Mar 1, 2021 at 5:16 PM Post #712 of 739
yes, JH Audio ships an aluminum case with the Lolas. It is quite high quality. With the case, I enjoy being able to toss the CIEMs into my backpack without worrying about them getting damaged.
Mar 1, 2021 at 5:18 PM Post #713 of 739
Thanks for your reply, that case looks like it can withstand literally everything :)
Enjoy your setup :beerchug:
Mar 1, 2021 at 10:14 PM Post #714 of 739
One of the best cases for IEMs.
Btw, as you're around... Would Ifi pro line-up work well with JH IEMs? What about Diablo?
Mar 2, 2021 at 5:42 PM Post #715 of 739
iDSD Diablo would require a separate iEMatch for sensitive CIEMs/IEMs, but something like Pro iDSD could work.
Mar 4, 2021 at 2:05 AM Post #716 of 739
Going to the Lolas from my other upper mid boosted iems takes a little getting use to. I really enjoy the balanced presentation.
Between the 7k peak and the balanced tuning it more or less negates the upper mid recession.
Mar 5, 2021 at 2:17 PM Post #717 of 739
Introducing Jolene! Two 9.2 dynamics in a Dome configuration for sub bass. Two 4.9 dynamics in a Dome configuration like Lola for mids. Four BA array for highs and a four BA array for super highs.
Mar 5, 2021 at 3:50 PM Post #718 of 739
I wonder how Jolene will sound, I have no experience with jh audio iems rather then a 5min listen to a set from @riverground and the 1 time I think it was a layla ion at a canjam.
Do they get any ear fatigue from sound pressure? I see there is no apex modules here.
How would lola or jolene sound vs a fourte?
Less treble? More natural sound?
Mar 5, 2021 at 4:52 PM Post #719 of 739
Jolene sounds intriguing, look forward to reading some reviews.
Mar 5, 2021 at 5:10 PM Post #720 of 739
I am ready for DD bass on JH audio
Jolene does sound like it'll be sweet.
