MarkTwain
- Jul 30, 2010
Thanks very much for your opinions, think I will go with the Layla II
You will love it.
You will love it.
Hope so, but considering what I heard about it so far I think this will be true.
Got the Layla II now .... man are they big
Problem is that the normal 3.5 mm cable is missing, it only came with the 2.5 balanced one (got them from a private seller).
Do you know if its possible to use the 2.5mm balanced cable with an adaptor to 3.5mm ?
Also which replacement cable 3.5 would you recommend ?
THX very much for your help
Thanks very much, just saw that the standard cable for the Siren Series by Moon Audio is 100 $ , so not that expensive .. thinking to get that one as I am also not a believer in cable affect sound
It is a nice cable as well. Just a bit thicker than the Black Dragon...
Hi,
Roxanne II owner here, been using it for a couple of weeks. Using QP1R and dac/amp TEAC HA-P5.
Loving the set so much as it's a big jump from using monster miles davis trumpet iem straight to samsung note 5 and spotify.
Prior to purchasing I audition it with angie 2 and layla 2 using ak240. To my surprise I actually like how roxanne 2 sounds better than layla 2, hence getting it from the original plan of purchasing layla 2.
@both: The SpinFits have a unique design in that they "flex" to fit deeper in the canal. What makes the Spiral Dots different from your average IEM-supplied silicon tip?
Spiral dot tips are just a tad bit smaller than spinfit tips size. The difference is not like another size difference, but it's there. The numbers above are just measurements provided by the manufacturers of the flange diameter so it's not wrong. The tips are just different. I could fit the medium sized spiral dot tip, but they were hurting and the medium small fits me pretty well. For the spinfit tips, I had a hard time fitting the medium and small is just slightly slightly large. If you can fit the medium spinfit tips, you can definitely fit the medium spiral dot tips without problem. They are different tips after all with different thickness and different bore size, so even if the diameter is exactly the same, it's impossible to get the same fit...
So now that I've finally got myself some Spiral Dots I have no idea what all the fuss is all about. 30$ for relatively standard silicon tips...hmm.
And what's with the dots... ? They cant possibly contribute acoustically as they are hidden by the IEM's bore (at least in the case of the Angies). At best, they make for a better grip (or perhaps just the opposite, make it easier to remove)... .
While seal and comfort are key factors, the sonic characteristics of a given tip combined with a specific IEM will also play an important role. Here's my simple comparison. Treble is highly affected by how deep / shallow the bore of the IEM sits underneath the tip. I think material / material's thickness also plays a role.
nice share ... also nice shoot ...
