Ivabign
- Jan 16, 2012
Interesting - can't say the drivers are that huge, but they have some distance from the nozzle (freqphase)
Thank you, you saved my day!
I miss the comfort of my old westone 4R, the combination of westone star tips with Angie could be a winner
the compatibility is a big surprise to me, i think the hole in the star tip is veeery narrow
P.S. Angie + Herbie Hancock / Return Of The Headhunters = Eargasm
Holy cow, are those the HF drivers crammed all the way into the lobe? That is significantly different from my Roxannes, there is nowhere near as much of a difference between the length of the mid and high tube.
Also, do my eyes deceive me or does the steel not go all the way to the drivers? I was under the impression the entire tube was steel... guess it's just the bore in the canal portion?
Ps. those bores are tinyyyyy. I really hope you never get any wax shoved in there, it looks like you'll have no wiggle room to clean it out :|
Start tips have the right balance of suppleness vs hardness, for me. Never hurts the ear canals, even after 4 hrs of continuous use.
Yeah um I haven't touched my IE800 & SE846 since I got the Angie's either.
Yup, mission completed the star tips by westone "married" with Angie
Strange, the same size (the black one) i´ve used with 4R feels not so comfy now. Less pressure/pain compared to spin fits, but still not perfect like 4R
Pros: better seal + BASS
Cons: a little bit veiled treble (compared to Angie with spinfits)
I have to find out how to increase the hole in star tips... maybe hot air from hairdryer and some tool...
I've had these for just over a week now and they continue to amaze me with their sheer amazing sound quality, can't praise them high enough.
The level of depth and detail to my music is outstanding. Fit wise I'm using the medium silicone tips with no issues, every so often I have to re-adjust the right earpiece but I get this with most iem's I've owned over the years.
I do wonder if I should be using a higher end source but I think what I'm using will suffice for now. Using my LG G4 smartphone with an Oppo HA-2 DAC/Amp. Mainly using on low gain although do sometimes switch to high gain. Most of my listening is through the Onkyo app and using a mixture of Flac and some 24bit files. Also using Spotify.
Yup, still thoroughly enjoying my Angie out of the ALO Rx (new IEM only version). Simply amazing sound quality.
The HA-2 seems like a good source for the Angie. Highly detailed DAC/amp.
