StevieBuns
- May 24, 2013
Hello all, I tried finding a solution to this elsewhere but wasn't able to find much information. I'm using jh5 pros with a Fiio E17, all the eq settings are default and i'm hearing a static or rattling sound in most of my music. I get this without the E17 as well, if I were to just listen straight from my Clip Zip playing FLAC music. It is difficult for me to describe exactly what it sounds like, but static/rattling is the best i've come up with. I don't hear it on every song, but most of my library I do. I was worried this could be an issue with the iems themselves? I had the gain on the E17 on 6db which was default, I changed this to 0 and I found that it did help on a lot of songs but it is still there. Any help is greatly appreciated.
Thanks very much,
Steve
Thanks very much,
Steve
