doobooloo
- Nov 3, 2002
Looks great! I am seriously considering these as a cheaper alternative to my UE-10 Pros!
Originally Posted by Jens Nylander (...) we have an industrial design team which is well-known in Scandinavia These comments we belive is the most important in our future development. Jens Nylander |
Originally Posted by kramer5150 Sit tight fellas!! Im reviewing a first off- prototype now. I believe I have the ONLY pair in North America in my happy little paws. Garrett |
Originally Posted by wowie11 How do they compare to the mid-priced universal IEM's in the market (UM2's, SF Pro 5, E5, E4, ER4, etc.)? Good to find out one of our bay area head-fiers have gotten a hand in the testing of this product. |
Originally Posted by Head Creep Comfortable, balanced sound, good isolation, a MS-1 comparison, low price... I smell a FOTM... A question I'm sure will be asked sooner or later: how do they sound unamped? And is there a significant difference between amped and unamped usage? |
Originally Posted by kramer5150 OK everyone, Here are my final D-Jays impressions Sources Used: Creative Muvo TX Creative Nomad Jukebox Sony D335 Sony D223 Magnavox AZ 6816, 6833, 6811 Of all my portable amps I found the pimeta and govibe II sound the best with the D-jays. My mints also sounded good, but these amps are high gain circuits that aren't suited for low impedence loads. Small... VERY small!! About the size of a chicklets gum. Nice low profile, they fit inside my ears. I can lie ON them at night when I sleep. GREAT symmetric "Y" cord. Comfortable soft silicone tips, I can wear them for hours at a time (something I can't do with my shure e2c). Very ipod Looking... Like an AKG K701 Sonic Impressions: I've had them for several days now commuting around the Cisco campus and in the office. Smooth. Balanced. Accurate with gently rolled off treble and low bass. Bass is tight and well defined across the spectrum. Vocals and solo instruments project nicely, without being harsh and certainly do not fatigue. Good treble extension too compared to the e2c, which we all know has severely rolled off treble. Very good spectral balance. Spectrally, similar to an MS1, with less bass-bloat and bass-impact. Not particularly bright or dark, and doesn't seem to emphasize or drastically attenuate any particular frequency bands. The fore-mentioned treble and low-bass seem to roll off at the ends of the spectrum, push midrange sounds forward. Midrange detail and refinement are its strong point. Mids are foreword, dynamic and detailed, yet not harsh and certainly do not fatigue in any way. Clarity and instrument separation are another strong point. Particularly with acoustic guitars. Very good clarity for an isolating IEM in this price range. Clearly superior to the shure e2c from a clarity standpoint. There are times it sounded a little bass-shy, but my ears have been conditioned to Grados and various Koss phones, which are known for having a good amount of bass excess. The D-Jayes are very versatile with EQ settings. On some tracks I found myself dialing in 2-3 db of bass boost below ~150Hz. Overall they handled my EQ tweeks very well, with no signs of clipping, distortion or “distress”. It also isolates very well, although its isolation seems to be somewhat frequency dependent. It completely blocks ambient noise below ~5000hz. Sounds like a running water faucet, passing wind from cars, and my keyboard as I type this leak through just a little, although they are significantly attenuated. IMHO this is probably the result of the silicone tips. I'm willing to bet foam-tips would completely seal outside noise across the spectrum , for listeners who want to be completely isolated from the ambient world. **EDIT** One more thing to note... the D-Jays is a revealing phone too. It doesn't muffle and recess treble. It is a low impedence, high sensitivity IEM.... so well designed amplification (note I didn't say expensive) is a must. My higher gain amps are far too hissy for these IEMs. I have some mints and a little dot micro that work very well with my high impedence phones, but just are not suited for sensitive IEMs. I found my pimeta and govibe synnergize very well with the D-Jays IEM. Comfort and design: Great Job on the ergonomics!!! Nice soft tips that don't exert much pressure on my ear canals. Compared to my shure e2c, the D-Jays are MUCH more comfortable. The e2c feels like a cork jammed in my ear, since they really exert a lot of pressure and they make my ear canals itch after ~45 minutes. Its nice how the D-Jays cord doesn't loop around the back of my ear. It makes ear insertion very easy, since you just let the wire hang loose. They are really small too and don't stick out at all. I can physically lie down on them at night, something I cant do with my Sony EX90, EX51, or Shure e2c. The symmetric "Y" cord is VERY nice. I don't like the lop-sided cord design of my EX90 and EX51. I know some of you have asked for pics. But I have been asked to hold off on posting pics, since the prototype has a different strain relief design. The prototype also had some glue visible, so cosmetically they aren't really an accurate representation of the production model. Jays will have a formal press release later, with pics, accessory information, ordering information and other goodies. Stay Tuned!! Garrett |
