donunus
- Nov 12, 2004
Ive read the tone audio review of the wa3+ and the wa6 and they said that the hd650s sound much better on the 6. Anyone compare these two amps and can confirm this?
Originally Posted by donunus /img/forum/go_quote.gif Ive read the tone audio review of the wa3+ and the wa6 and they said that the hd650s sound much better on the 6. Anyone compare these two amps and can confirm this? |
Originally Posted by Happy Camper /img/forum/go_quote.gif Get a 6 se or look elsewhere. You start getting the power supply needed to control these phones with the energy to make them sing. The cap upgrade will make this a fine amp for an all rounder. |
Originally Posted by Vandal /img/forum/go_quote.gif I wish I could. 1050 US$ is like a months salary for me; too much to spend ATM. |
Originally Posted by Redcarmoose /img/forum/go_quote.gif Limp Bizkit-CSATHDFW Interscope Records Lp 2000 Celtic Frost-Into The Pandemonium Earmark 1999 Guns N' Roses-Apetite For Destruction Greffen 2008 Alice Cooper-Constrictor MCA 1986 MSG-One Night at Budokan Chrysalis 1981 Would the Bugle Boy 6DJ8 work for the standard Woo Audio 3 too? |
Originally Posted by Happy Camper /img/forum/go_quote.gif Fully understand. I had to save 6 mos to get my amp. I'm still putting my spare change away for a new source. Been saving over a year. If you want something competent without getting the very best the hp can do, the standard 6 will sound good. You can diy upgrades or send it back if a boon comes your way. I don't think Woo would offer the upgraded units unless there was room for improvement with the basic unit. They don't put on gold trim and crystals. As far as the importance of a power supply to an amp, that is the amp. Fast, large power reserves, clean power, properly designed grounding make a big difference between making noise and controlling a driver properly. My ipod moves the 701s to get sound but won't move the driver like my SP. When it runs the 701s, there is no dampening needed from the hp. The amp controls the starting and stopping with authority. Every nuance of signal gets to the drivers. When driving a complex signal, the soundstage stays intact instead of collapsing, sustained note energy stays even instead of dropping down because of lack of reserve juice. All that is based on the power supply. |
Yup, same tube selections apply for both versions, although if that's the kind of musi you'll listen to, I don't think the Amperex 6DJ8 is the best choice for you...you'd be better off with maybe a Siemens or Telefunken 6922 equivalent (the E88CC). |
Originally Posted by Vandal /img/forum/go_quote.gif Maybe I should put it this way. Will the WA6 without any upgrades still be better than the WA3+ with both high and low impedance cans?? |
Originally Posted by donunus /img/forum/go_quote.gif From reading the tone audio review, they should be similar with low impedance cans but the wa6 is better with the senn 650s so probably better for high impedance cans... I am interested to know more about this also |
Originally Posted by Redcarmoose /img/forum/go_quote.gif You rock Golden Monkey.......Thankyou I'll try to roll em like you said. |
