TheMarchingMule
Febs the Audio Sleuth solved it!
Originally Posted by Febs /img/forum/go_quote.gif In EAC, go to "EAC Options" --> "Normalize," and make sure that the "normalize to" option is unchecked. |
Originally Posted by Febs /img/forum/go_quote.gif Bingo. In EAC, go to "EAC Options" --> "Normalize," and make sure that the "normalize to" option is unchecked. |
Originally Posted by IPodPJ /img/forum/go_quote.gif Then rip a WAV file through iTunes and the same one with EAC. You will be able to easily tell that the one extracted with EAC sounds exactly like the CD playing in the drive. The one ripped from iTunes does not. |
Originally Posted by IPodPJ /img/forum/go_quote.gif Nope, my normalize button is not checked. My EAC is not normalizing anything. EAC isn't the problem, iTunes is. Put a CD in your drive and play it through Foobar. Then pick a song and rip a WAV file through iTunes and a WAV file with EAC. You will be able to easily tell that the one extracted with EAC sounds exactly like the CD playing in the drive. The one ripped from iTunes does not. |
Originally Posted by Febs /img/forum/go_quote.gif Did you not read my post? I just did exactly this, and confirmed that the EAC rip and an iTunes rip are identical. |
Originally Posted by Febs /img/forum/go_quote.gif Bingo. In EAC, go to "EAC Options" --> "Normalize," and make sure that the "normalize to" option is unchecked. Comparison of iTunes rip with EAC rip with the "normalize" option unchecked in EAC: |
Originally Posted by IPodPJ /img/forum/go_quote.gif Yes, I see what you did. That's what I've been doing all along and the results are different. Bigshot, I'm going to try iTunes with error correction mode enabled and see what results I get. Hopefully then they will be identical. |
Originally Posted by Febs /img/forum/go_quote.gif It is entirely possible that a bad rip is the issue. I happened to do my test with a brand new CD that I literally just opened, so it's not too surprising that my rips were the same even without error correction mode enabled. Just to eliminate one other potential issue, in iTunes, check under "Advanced" --> "Importing" --> "Setting." What setting do you have selected? (If you have the sample rate set to something less than 44.1kHz, that would explain why you're experience a high-end rolloff.) |
Originally Posted by IPodPJ /img/forum/go_quote.gif It made the CD player sound like it was grinding against a belt sander, off and on for about 2 minutes. Then it showed the green checkmark symbol to indicate it copied, but nothing at all copied except the file name. The progress bar didn't move one iota and the new files now listed in iTunes have a time of 0:00. |
Originally Posted by IPodPJ /img/forum/go_quote.gif Ok, iTunes with error correction mode enabled did not work at all. I tried it with two CDs. It made the CD player sound like it was grinding against a belt sander, off and on for about 2 minutes |
Originally Posted by IPodPJ /img/forum/go_quote.gif Ok, iTunes with error correction mode enabled did not work at all. I tried it with two CDs. It made the CD player sound like it was grinding against a belt sander, off and on for about 2 minutes. Then it showed the green checkmark symbol to indicate it copied, but nothing at all copied except the file name. The progress bar didn't move one iota and the new files now listed in iTunes have a time of 0:00. |
Originally Posted by vcoheda /img/forum/go_quote.gif use wav files. problem solved. |
