I have a quick question regrading power cables, i have a stock cable thin rubbishy thing which is 13amp 250v , the spec on the unit it powers is 240v 50hz\60hz 1A , does the 1A stand for 1 amp? , so it is ok to replace the 13amp power cord with a 3amp 1 since the unit actually only requires 1amp. It's a 300watt amp so i doubt it draws in thousands of watts of power.
If the unit only requires 1 amp then a 3 amp cable will be fine.
It is quite funny that you describe the stock cable as a "thin rubbishy thing".
There won't be any advantage in using a voodoo power cable over the stock cable which you are disparaging.
It is just auto-suggestion. You have prepared yourself for being impressed by the, no doubt more expensive, replacement I see by already describing your perfectly good standard cable as "rubbishy".
You can put in the more expensive replacement and no doubt you will believe that the sound quality has improved in some way. But it hasn't. You will have been conned. It is true that the sound quality will appear to have been improved as long as you believe it has been
Unfortunately that belief just wears off after a while unless you keep refreshing it by reading more articles etc. promoting voodoo in cables.
If I were you I would use the stock cable which will work just as well as the replacement.
