Is you hearing symmetric?
Mar 21, 2010 at 2:39 AM Post #16 of 34
Well both of my ears tested the same oddly, exactly. I didn't feel the need to alter anything.
I set my Mac iTunes and DVD player for this equalizer setting. It's ironic, cause the setting I usually use is a small V shape, which is almost just what the result came out to be.
Mar 21, 2010 at 1:53 PM Post #17 of 34
I played violin and I blame that on the minor hearing loss in my left ear. It's only a problem when someone is talking very low on my left side or while wearing headphones (and aggravated by certain types of recordings with minimal crossfeeding), otherwise my brain will compensate and I won't consciously hear the discrepancy. My ear canals are not identical either, so that contributes a little to my confusion
my advice is to just ignore the difference and eventually your brain will adapt to it, and be able to transition between listening to headphones and listening to real life sounds with less confusion.
Mar 21, 2010 at 2:40 PM Post #18 of 34
What about custom IEMs? Shouldn't they neglect the ear canal differences?
Mar 22, 2010 at 10:07 AM Post #19 of 34
I blame my rattle gun I used at work to do up and undo wheel bolts. I held the gun up high near my left ear - so now I think everything is balanced to the right. Other wise I was also believing it had a lot to do with whether one was left or right handed. I also find my IEM to be more unbalanced - nevertheless I just ignore it now.
Mar 22, 2010 at 11:59 AM Post #20 of 34
My hearing is bit asymmetrical. My left ear is bit more sensitive to treble so music I listen with headphones is very slightly balanced to the left, and sometimes it bugs me a bit.
Checked my hearing on doctor (not real audiologist, but good enough) and results were that my hearing is oversensitive and above average line, but right had a small dip in treble, which was still above the average line. I guess its that dip what is screwing my hearing balance.
Mar 23, 2010 at 10:50 PM Post #21 of 34
What about recordings themselves? I am pretty sure that most of the modern recordings have more instruments in the right channel. This might make us blame our hearing.
Mar 24, 2010 at 1:13 AM Post #23 of 34
Who knows maybe mainstream listeners prefer more sound in the right ear.
Mar 24, 2010 at 1:16 AM Post #24 of 34
I hope not, because that's just wrong.
Just give them mono and balance it more to the right. They won't know the difference.
Mar 24, 2010 at 2:13 AM Post #25 of 34
Right now I am listening to Rush - Time And Motion. Bass guitar seems to be slightly on the right side. Is this my ears or it is indeed on the right side?
Mar 24, 2010 at 2:41 AM Post #26 of 34
Just thought I'd chime in.
A lot of headphones themselves are assymetrical, and you really shouldn't be judging your hearing on anything other than equipment designed for audiometric purposes. Although "indetectable" difference, I think 1 dB is the tolerance for a lot of ~$500 mark headphones. Although a change in volume of 1dB is almost indistinguishable (for the average person), a differential SPL certainly is IME, anyway
If you are hearing slightly off centre, it could very easily be either due to the recording (I find recordings tend to favour the left side rather than the right if they are off-centre slightly), or even due to your headphones. It could also be caused by fault caps etc in dac/amp but you would probably know when that is the case.
Just something to be aware of. If you are truly concerned about your hearing, get it done by a professional.
Mar 25, 2010 at 11:09 AM Post #27 of 34
OK its really bugging me now.
what does IME and AFAIK mean? I see it all the time but never figured it out. IMO = in my opinion - I worked out, but IME?
Mar 25, 2010 at 12:42 PM Post #29 of 34
The matching between left/right is usually only done at one or a handful at most of frequencies. Measurements show the matching between headphones at any price range to be quite a bit worse than 1dB, except a few headphones with specified tolerances across the entire spectrum. HeadRoom has graphs of these where you can see this for yourself.
Mar 25, 2010 at 1:07 PM Post #30 of 34
You know, I get this too!
I have yet to have any formal testing, but any testing I do would suggest I have symetrical hearing. Yet, sometimes when I listen to music, on occasion, I start wondering if everything is equal!
However, I think that due to the crazy channel separation and low crosstalk, it will simply seem like this at different parts of a song. Like a ride being only in one ear, bass being in the other. Different frequencies are perceived at different volumes for the same loudness etc etc.
If I am not worrying about it, I never notice. It is only when I worry that I think so...
Even if your hearing isn't perfect, I would just try and forget about it, as there is nothing you can really to.
Also, I had an ear blocked by fluid for a while and had to have a nasal steroid to clear that up. After I noticed I stopped worrying almost completely.
