johncarm
- Nov 10, 2013
evidence of the accuracy of echoic memory, well, does it matter? it's not like long listening bypasses echoic memory, so whatever inaccuracy will at the minimum be ported onto the next step of memorization. there is no memory of sound that we got without the echoic memory step anyway.
evidence that more time leads to more mistakes in recalling audio information, well there is your everyday life experience. else I remember 2 papers on the subject, but finding them again is another story. I have pdfs and bookmarks about audio that are like the treasure cave in ali baba. I know how to open the cave, but then it's just a giant mess of all the stuff I will mostly never read again that I didn't even care to rename properly for the sake of future search ^_^.
but in any way you won't be satisfied by those, as to test short vs longer recall, the test requires to have a short sample in the first place so that it doesn't exceed the echoic step.
again what you explain sounds to me like when I would want to analyze music in my head to get a sense of something, a perceived preference or whatever. and that is not the purpose of a blind test!!! I'm not saying long listening can't have it's use or that we should judge music based only on short samples. let's make this very clear, I'm talking about trying to discriminate 2 audio samples here! nothing else. now let's say I'm setting up my EQ, to decide if I'll keep it, just turning it ON and OFF a few times is not a good method because my impressions will be impacted by the "louder is better" feeling. instead I'll use that EQ for some times, then turn it off and listen again without any particular timing or agenda. only then will I decide if I preferred one or the other. that's taste.
but if my question was "is this EQ sounding audibly different compared to no EQ?" then of course I would just turn the EQ ON/OFF repeatedly while playing music and see if I detect a change.
It's not "the accuracy of echoic memory", it's the accuracy of the comparison in echoic memory.
Second, there's no need to analyze music. I'm simply describing the reality of a musical signal which is that it has repeated similar but slightly different features.
The big questions here are (1) what is our model of aural memory, and (2) how does that inform our choice of test signal.
Say we are choosing between a signal that repeats features many times, versus a signal that has only one repetition of each feature. What does your model of aural memory have to say about that? How does the difference between those two kinds of signals affect the way they are remembered, in your model of memory?
