Is there scientific evidence that "Pink Noise"-Burn-In changes the sound?
post-7004461
Post #211 of 304
kiteki
aka Theta Alpha 1
aka Alpha Zeta 5
aka Alpha Zeta 6
aka Nanocat Systems
And many other aliases
I imagine the material used in the speaker diaphragm has a reasonable impact on burn-in/break-in....
The sonic property of a crystal champagne glass, or metal turning fork, will remain the same for a very long time.
The sonic property of your sneakers will change rapidly.
Unless an extremely thin layer of a hard material like diamond or kevlar changes it's shape/hardness/elasticity to an extent which will transmit soundwaves differently, I can't imagine diamond changing with break-in... much like pair of lady shoes made out of glass.
post-7004475
Post #212 of 304
Nebby
I couldn't resist...when did we move from break-in of speakers to break-in of shoes?
post-7017517
Post #216 of 304
TheDreamthinker
Some many pros here and still no real breakthrough...
post-7017573
Post #217 of 304
Nebby
There isn't really a breakthrough to be had. Only way to have a definitive answer is a properly done test of drivers/headphones with a full suite of tests done to the drivers/headphones before, after, and after cool-down of burn-in. Unfortunately that's not a small task and it's unlikely anyone will volunteer to pay for drivers/headphones, test equipment, and volunteer so much of their time to do something like that. About the only person that's remotely setup to do it would be Tyll with his measurement lab, but even then there's the issue of who'll pay for the time and hardware.
post-7018576
Post #218 of 304
Antony6555
I hope this has been said (I haven't read the whole thread), but again a simple dbt would answer this question. Yes there are probably some absolute changes to the sound, but it's only relevant if such changes can be perceived by humans.
post-7018722
Post #219 of 304
Nebby
Not nearly so simple, as you would have to make sure that the two pairs of headphones are identical in terms of frequency response out of the box to ensure that you're only testing the burn-in, not the differing frequency response due to manufacturing variances.
post-7018921
Post #220 of 304
Antony6555
You could just dbt them when you first bought them, then dbt them after burn-in.
post-7018957
Post #221 of 304
Nebby
How do the two dbt's correlate between each other then? Given that you have at least a hundred hours between each session, you will be introducing the factor of memory into the equation. Memory is terribly inaccurate
Unless.....you have a time machine you haven't told us about.[/joke]
post-7018986
Post #222 of 304
Antony6555
They don't correlate to each other at all, the two dbts are not related. First, you take the two phones and dbt them to make sure they sound the same out of the box. Then, you let one burn-in and dbt again (you're not comparing the two tests).
post-7018997
Post #223 of 304
Albedo
Can the movement of earwax in the test-time also be of any importance, also wonder about the blood pressure/ pulse do effects the inner ear?
post-7019030
Post #224 of 304
kiteki
aka Theta Alpha 1
aka Alpha Zeta 5
aka Alpha Zeta 6
aka Nanocat Systems
someone on youtube called rat something did a burn-in test and found conclusive evidence in a radioshack soundwave thing
post-7019077
Post #225 of 304
Nebby
I see what you mean now, thanks for the clarification. Hopefully the two phones sound the same out of the box, otherwise it'll be fun trying to get matched set.
I would also say that one could interpret the subject line of the thread as two different questions. One is whether "is there scientific evidence that...burn-in changes the sound", while the other question would be "is there scientific evidence that...burn-in audibly changes the sound." Some measurable changes in sound are not audible to the human ear, so a DBT would answer the second question, whereas a measurement test would answer the first.
I'm highly skeptical of any conclusive measurements made with a radioshack device.
