proid
- Mar 21, 2011
The O2 amp using either AC regulated or battery power supply. As my ear and I have read quite a few post claim that there is no different in sound quality between using adapter or battery or maybe more bass punch from adapter because of higher current capability. But as my knowledge, battery is the most linear power supply and O2 only using simple LM7812/7912 with some capacitors to regulate and even a half-wave recitifier which is more ripple than full-wave recitifier. So is the high-end power supply like the Sigma 22 really worth it when even a simple regulator circuit give the sound no different then battery or because O2 doesn't need really good power supply?
