Hennyo
Caution: Incomplete trades.
- Dec 26, 2010
I am undergoing building KGSSHV, and I'm ******* proud of it.
I am undergoing building KGSSHV, and I'm ******* proud of it.![]()
Khozmo Quad Attenuator
Still waiting on the Case and Transformer, should be testing soon.
Just like to thank Kevin for making this build easy enough to understand for general DIYers.
Looks nice. Is there any particular reason why you chose the Khozmo Quad Attenuator instead of the Alps RK50? I am just curious to know. Some people told me that the Khozmo Quad Attenuator is cheaper and better than the Alps RK50. Do you agree with that?
s
Someone told you wrong.
I'm at about the same point - I forgot to purchase a 3k resistor, and am waiting on my transformer and LSK389s. Otherwise things are going great! Mine are offboard though, and I'm having a local guy drill up my angle brackets and heatsinks - should be a relatively unique build![]()
s
Which 3K resistor are you going to use for the Bias? The Xicon resistor was out of stock from Mouser when I ordered. The Vishay resistor I ordered to replace it was spec'ed as the same rating.
s
The Khozmo is rated +/- 0.1dB for channel matching, from the first step to the last. No pot, including the RK50 can touch that. In terms of sound, I suspect the RK50 probably outperforms the standard Khozmo with Caddock resistors. The Z-foil versions may be a different story.
