chungsoi
- Nov 27, 2004
double post
Originally Posted by bangraman I got myself a ZCover until Agent 18 Videoshields appear on this side of the pond. I was thoroughly impressed with the Agent 18 Nano case. It was well thought out, genuinely protective without adding tons of bulk and fully retained the usability of the iPod, including docking. I hope the Videoshield is the same... |
Originally Posted by chungsoi It's a temp option until my shield + agent18 arrives. |
Originally Posted by knalb what are you using to strap your ipod to your amp? is that just a really fat black rubberband? |
Originally Posted by gshan I thought the pricing was farely reasonable on the nano agent18 also. Is the plastic really slippery, btw? I like the rubber sleeves because they add a little grip. |
Originally Posted by max-9 Try a condom to protect your ipod.....Trozan (non-lubricated). It fits an ipod video but is to big for the nano. And in the case of an unexpected encounter....you can quickly remove the trojan from the ipod and protect yourself. (important note :dont put used condom back on ipod!) |
