Sorry, radoc. I assumed you knew what constituted abuse as it relates to these batteries. By abuse, I don't mean banging on them with a heavy object, though that would undoubtedly qualify. What I'm referring to is simply the mistreatment common to the uninformed user. For example, leaving the device in a hot car, exposing it to prolonged direct sun (such as at the beach), and--according to Apple--even charging while contained in some cases. These will
permanently reduce the battery's capacity. Another common abuse, as we've discussed, involves routine full discharges. I took all this, since it's been covered by
many of us, to be common knowledge. It may have even been mentioned in this seemingly endless thread.
Regarding your example of 75 percent depletion per day versus 75 percent depletion over three days (assuming I understand you): I've never claimed that the number of charge cycles is meaningles--far from it. And keep in mind that the life expectancy of the battery is
two to three years, although, with care, I believe this to be low.
In your second example one would be better off to charge the device each day (assuming a rate of 25 percent daily discharge) rather than waiting until it reaches 75 percent. Remember, these things aren't at all linear. For example, a typical fully depleted Li-Ion reaches an 80 percent charge state in one hour. But 100 percent (only 20 percent more) requires three hours. I'm sure you already know about the safety circuitry involved.
The point is that these batteries fare best with shallow discharges, and the shallower the better. But this primarily affects the number of cycles, not the time-based life expectancy. In your example of 75 percent per day compared to, say, 25 percent per day, neither would appear to have an advantage since both will likely succumb to age. But there are other considerations. Although both may well die of old age, the 25 percent per day unit will maintain a higher percentage of its total capacity over time. By this I mean that the 25 percent model may be able to reach perhaps 65 percent of its original capacity after 30 months, whereas the one discharged 75 percent (all else being equal) would be somewhat lower.
Of course, if the 75 percent figure is increased to 90 percent, the number of cycles can drop significantly and the battery will almost certainly be cycle limited.
Sorry to run, but I've got to go stand in front of a mirrored wall and wave my arms bit. No, you haven't driven me around the bend, I'm just practicing a speech.
