flashman
- Apr 25, 2009
Hi darkfury18,
thank you for your description.
I tried before the cf mod with my 3g ipod but never worked. now i found your advice to change a byte. i am curious if it works....
i cant find the right byte at 0x4230 Please can you or someone tell me how to get there? the value i found was 61. I was simply following the bytes until the program XVI32 showed the location 4230. Was this right? Were is the offset 0x? I thought its just in the beginning of the file....
thank you very much for a short reply...
