Thanks again everyone for your welcome. This is a great place.
pabbi1, I noticed in your profile you say
I'm scared... 2.7k resistors on
R11/R61 for the SDS. LOL. That means you're running a voltage gain
of 3.7. I guess I should be *really* scared then... I am running a
gain of 5!
I thought I'd post a rundown on how my SDS amp differs from Sheldon's
original v1.2 design, as follows:
- I eliminated R12/R62, and substituted R10/R60 with 4.7mA CRDs
(Vishay/Siliconix CR470). This sources a steady 4.7mA current out of the op
amp output for class A operation (rather than sinking an amount of current
that varies depending on the bias pot setting and supply voltage). Also this
greatly improves the PSRR.
- Added a 475 ohm resistor between the volume pot's center contact
and the input of the amp. This is so that when the volume is all
the way down, the + input to the op amp is grounded through that
resistor rather than directly. This balances the 475 ohm resistor
on the - input side (see 4. below). Not a big deal with the FET
op amps however.
- I installed R5/R55 (1M ohm) anyway, just in case the volume pot
should go open circuit or become disconnected, the + input of the op amp
won't go floating which would be bad.
- The feedback resistors I used are R11/R61 = 1.82K, R6/R56 = 475 ohm
for a voltage gain of 5 (actually, 4.83 to be exact).
- I used a 33pF capacitor for C16/C66 to ensure stability with
the ultra fast op amps. This adds a roll-off pole beginning at
2.6MHz toward unity gain. However I reduced C11/C61 to 10pF. This
gives optimal step response with the AD8066AR while also working fine with
the other op amps I tested with.
- I replaced R2/R4 with 10K 25-turn Bourns cermet trimpots to allow me
to adjust the regulator voltage. I have it set to ±12V to work
with the AD8066AR and AD8620AR. I found that even with hand-matched
fixed resistors, the positive and negative regulators do not match
each other in output voltage very well, so using the trimpot allows
me to fine tune it.
- Added a 4700uF 50V Elna electrolytic cap each in parallel with
C5/C6, these are the large chassis mounted caps at the rear of the amp.
- Added extra bypass capacitors to the power supply: 0.47uF tantalums to the
input side of the voltage regulators, 0.22uF to the output side.
In addition, I added a 0.1uF multilayer ceramic cap directly across the
V+ and V- pads of the op amp.
- I used 121 ohms for R7/R57 because I happen to have these around.
- R13/R14/R63/R64 are 332 ohms (MOSFET gate resistors).
- R8/R9/R58/R59 are 2W flameproof metal film resistors.
- The Q1/Q2/Q51/Q52 MOSFETs are IRFZ24N (N-ch) and IRF9Z34N (P-ch). I
have not seen anyone use these devices in this forum, but they work
great and are available from Digikey and Newark.
- Q3/Q53 are Motorola 2N5210 low noise NPNs that I have some of.
- The op amps are AD8620AR, AD8066AR or OPA2132PA (socketed for easy swap).
The AD devices are mounted on SOIC-to-DIP adapters.
- The bridge rectifier is an IRF 4GBU06.
- I used 1N4004 instead of 1N4007 for D1/D2 because I have some around.
- C1/C2/C3/C4 snubbers are 330pF multilayer ceramic caps.
- I used a Noble 50K stereo pot instead of the 100K Radio Shack unit for
the volume control.
- Different brand of resistors and capacitors, etc., than what Sheldon
specified in his parts list. E.g., Vishay/Dale RN55 1/8W resistors
instead of the Yageos. Nichicon, Kemet, Vishay, and Xicon caps, etc.
- Added a 3mm blue 3.5V LED with a 22K resistor in series, driven
across the unregulated supply rails (+22.5V to -22.5V) as a
power-on indicator.
In my case the extra power supply bypass caps were essential. Without them,
I observed a 1.6MHz oscillation from the voltage regulators (seen with
my Fluke scopemeter on both rails, but higher amplitude at around 200mV p-p
on the negative side). The oscillation occurs even without the op amp
plugged in, and feeds right through to the output.
This of course is not audible in itself, but I found some side effects.
When the MOSFET quiescent current was increased to over 50mA or so, there
was a slight hissing noise heard through my HD600s. Also, when powering up,
there was an annoying
bbrrraaaap noise for about a half second.
These are all completely eliminated with the added bypass caps. Now
the regulators run rock steady.
I think this speak volumes about the importance of an oscilloscope
when building an amp of any type. Otherwise the symptoms may have been
ignored or dismissed as something else, but surely would have adversely
affected the performance of the amp.
Anyway, sorry about the long post. I hope this info is interesting or
useful to SDS amp fans, or those who are looking to build an SDS amp.
-Ti
