DrSheep
- Nov 17, 2012
They are too high, the back canot be closed flash.
Just cut the pins.
1-Unit arrived just before Christmas, thank the gods of head-fi for not making wait a week till the next cycle! [24-12-2015]
I was not expecting to get the unit this quick but I did. The unit is infact very light, if you find Ak120 easy to carry this should be as easy. First impressions are quiet positive. This is the first DAP venturecraft has produced however I will not use that as a justification for any short coming on their behalf however so far for a first attempt it is a nicely done unit, I give them a pass however there are few things I liked improved:
But now lets focus on sound: In short it sounds very similar to AK240, very wide, well extended and detailing using stock opamp is adequate however that can easily be fixed. The magic of valoq is in us been able to fine tune the sound using different LPF. I know I cannot wait to figure this part out myself.
- The unit uses wheel for navigation:The scroll wheel design when done right can work (shanling M3 for instance) however the one used on Valoq seems loss, I like a bit more resistance.
- Scroll wheel is easy to spin, we must always lock it: Since it is so easy to spin the wheel which what it does is skip a few second in track (no big deal right) but if you want to FF a song this means you have to take the unit out of your pocket, unlock it and FF it.
- Where is my FF button: In order to FF a song it is required to press the scroll wheel hard twice.
- There is still a slight gap between song: Not truly gapless but the gap as stated in the audio setting is 100ms, still long enough for me to notice
- Quality check can be better: Sadly my unit has developed a white-line across the TFT screen, I think there is a set of faulty screens that they used on their early batches.
The balance out just offer excellent dynamic for my T8iE, I will test other IEM later, early days.
I will post pictures later tonight, promise![]()
Nice 1st impressions.
I find myself NOT locking it from my 2nd day of use, and the wheel never once spinned unintentionally inside my pocket. It really isn't THAT loose, but I can understand some may prefer a bit more resistance. But then AK's spinewheels are much looser than this....
Talking about wheels, the volume knob, I think, is done just right. Enough resistance to avoid accidental turning, but still smooth enough for fine adjustments.
And I can totally live with the rocker scroll wheel design - I'm quite used to this FF click twice / RW click 3 times thing since the days remotes on handfree headsets became popular.
Maybe some part of it can use some burn in, as it starts to sing heavenly on my 3rd day of use. Excellent synergy with my 3 go-to iems as of late: Fitear 335DWSR, Compact Monitors Stage 4 and, of cos, the T8iE.
Great impression, and mine will be here around the 29th along with my OpAmps.
Two thumbs up regarding muses01, the sound is no way bright, I was expecting it to be bright. The bass dynamic and control improved alot compared to stock.
Remember, the MUSES01 is underpower by the Valoq (min 9v, the DAP only gives 7v), so I have no idea how will this affect the chips. Go to know that you think it sounds good.
One question for the owners does it play dsd natively of dsd to pcm cause when I demo it the staff told me its dsd to pcm but the spec from venturecraft translate to english say its native dsd playback so which one is it?
I like what I am hearing and definitely an upgrade to my Jr in terms of SQ (clarity, separation, details, and yes organic vs analytical). To my ears this little player punched above its size regardless of $.
Merry Christmas all!
