me too!Im seriously considering this. It's between this and a FiiO K17.
Introducing the xDuoo TA-32 DAC/Hybrid Class-A Tube Amp - Now Available on Apos Audio
They feel like VERY different products. The xduoo seems to me to be more about the raw sound and the Tubes' influence over it while the Fiio is like a audio tweaker's dream. It is a swiss army knife of dac/amp/eq/streamer/DDC. The sound is also gonna sound more like a discrete solid state amp vs a tubey sounding amp like the xduoo.me too!
KipFox
Anyone know what the socket type/material is on this unit?
Torn between grabbing one of these or a deal on a WA7 Fireflies 3rd gen. Don't suppose anyone here has managed to hear both?
2x 12AU7 Tubes for amplification stage and a 5u4g rectification tube. What do you mean by material?Anyone know what the socket type/material is on this unit?
KipFox
Oh if they were using ceramic, ptfe or another material.2x 12AU7 Tubes for amplification stage and a 5u4g rectification tube. What do you mean by material?
no idea, sorryOh if they were using ceramic, ptfe or another material.
Edward Ng
Does the tube buffer add gain?Yes the "Tube" RCA out on the back is a preamp running through the circuit. There are balanced and single ended inputs that run though the preamp stage.
-Ed
Yes changing the gain level will affect the tube pre-out as well as the headphone outsDoes the tube buffer add gain?
-Ed
prinzpudding
To each their own I guess?Another toy alike designed amp from xduoo
Personally I love how TA-22 looks (much more than this TA-32). Sleek and modern.
You mean this?Another toy alike designed amp from xduoo
https://apos.audio/products/xduoo-d...GvFNOSnksKdVW-O_C-mVimM04ZVr1N44aAjMvEALw_wcB
I swapped some tubes and they look and feel ceramic.Oh if they were using ceramic, ptfe or another material.
I'm looking forward to getting one but it's a couple of months waiting. On Hifigo, it's a month before it can be delivered.
Wow this looks fantastic, enjoying my ta-20 plus with mullardsHi all,
We are really psyched to share with everyone the latest from xDuoo: the TA-32 High-performance DAC & Balanced Tube Class-A Headphone Amplifier. xDuoo’s famous for its lineup of budget-friendly products, so you may be initially sticker-shocked by the $999 price tag but wait until you hear what it’s packing: a matched pair of Ray Tubes 12AU7 CORE + a rectifier tube, and a class-A output stage, all in all boasting 3,000mW of output power; a swappable modular DAC card; Bluetooth 5.1 connectivity; and inputs for turntables, CD players, laptops, phones, and more, making it the lynchpin of any system.
Product highlights
- Up to 3000mW of power to drive 16–600Ω headphones
- USB DAC for Windows, macOS, iOS, Android, Linux, and more
- Coaxial and optical inputs supporting up to 24Bit/192kHz and DSD64
- Qualcomm QCC5125 chip for Bluetooth 5.1
- Tube rectification (5U4G) and matched pair of Ray Tubes 12AU7 CORE for the audio stage
- Replaceable DAC card for different sound signatures
- ROHM BD34301 DAC chip for low distortion and high resolution
- Tube + transistor hybrid amplifier architecture
- Capacitors chosen to enhance transparency and smoothness
Specs
- Screen: 3.12-inch OLED
- Power supply: AC 100–120V / 220–240V
- Compatible OS: Linux, Windows, macOS, iOS, Android
- USB IN sampling rate support:
- PCM: 16–32Bit / 44.1kHz–768kHz
- DSD: DSD64–DSD512
- MQA: 8x
- Optical/Coaxial sampling rate support:
- PCM: 16–24Bit / 44.1kHz–192kHz
- DSD: DSD64 (DOP)
- Bluetooth support formats: SBC, AAC, aptX, aptX LL, aptX HD, LDAC
- 6.5mm headphone output:
- Output power: 2300mW (32Ω)
- Frequency response: 20Hz–60kHz (±0.5dB)
- THD+N: ≤ 0.01%
- SNR: 116dB
- Crosstalk: 75dB
- 4.4mm & XLR headphone outputs:
- Output power: 3000mW (32Ω)
- THD+N: 0.03%
- SNR: 118dB
- Crosstalk: ≥ 104dB
- AUX out:
- Output level: 2.0Vrms
- Frequency response: 20Hz–20kHz (±0.5dB)
- THD+N: 0.0007%
- SNR: 117dB
- Crosstalk: ≥ 108dB
- BAL-LO:
- Output level: 4.0Vrms
- THD+N: 0.0006%
- SNR: 125dB
- Crosstalk: 113dB
- Suitable headphone impedance: 16–600Ω
- Size: 12.2 x 9.4 x 6.7in (31 x 24 x 17cm)
- Weight: 11.46lbs (5.2kg)
Here's the link to our blog for more information: https://apos.audio/blogs/news/meet-the-xduoo-ta-32-dac-hybrid-tube-amp
Ian Origbo
- Sep 20, 2016
If this had a remote I won't think twice. I'll get one straight away. My system is far from listening chair.
hongky
- Mar 13, 2013
Anyone here ever try Cayin HA-3A please give some impression how it's compare with TA-32 on SQ alone. I know it's different device but I really want to know how these two compare. Thank you very much
Also how ZMF Atrium sound with TA-32 if anyone have it, thanks again
