canthearyou
- Jan 27, 2015
Here http://www.head-fi.org/t/770610/introducing-the-matrix-m-stage-hpa-3u-and-hpa-3b-review-to-follow/60#post_12250417 I was able to measure about 1.5 Watts in single-ended and about 4.5 Watts in balanced operation with 60-62 ohms cables + resistors, so in 50 ohms it should have a little bit more power (perhaps with 10-15% more).
1) Good luck with this, I'm waiting for some nice screenshots and also for your first tests and opinions. I'm sure everything will go just fine, but take care anyway.
2) On the negative rail you should have around -18.2V, so from + to - there's still almost 36V anyway, very high for these BURSON op-amps that can support up to 30V max. Feel free to check what "only" +/-16.5V can do to them in Gustard H10 thread: http://www.head-fi.org/t/735828/gustard-h10-high-current-discrete-class-a-output-stage-headphone-amplifier/4260#post_12276557 and many other posts as well showing the V5s overheating and loosing the red case.Despite being completely users fault (nobody measured the voltage from inside H10 before starting to roll op-amps) BURSON created special op-amps for all H10 customers and the're gonna replace them all; these special op-amps can tolerate +/-17V and higher temps. They also created an aluminum bridge to get rid of the heat from inside H10. Now that's what I call customer service.
Really waiting for your test; if you can find an A/B testing device or if you can do some by yourself it would be great.
Thanks!
I would not say it was completely the users fault as the Burson website stated it was a direct replacement for the stock op-amps.
And I might pick up a Schiit Sys for direct comparisons.
