Hi. Just received my Hifiman combo package of HE1000V2, EF400 & HM800. Been contemplating R2R for a while now & finally decided to take the plunge.
Been using it with my R3 Saber Pro, LG V30 & iPad Pro as sources with Roon/MicroSD on my Tia Fourté Noir.
Although both are advertised to be using the Hymalaya DAC it’s quite obvious that the tiny HM800 is using a smaller FPGA R2R module with limited/lower resolution capabilities.
First impressions:
On initial USB C connection to the R3 Pro (as USB dock) all I could hear was static masking very faint music.
Thinking it was a 0.78 pin polarity issue tried reversing the supplied (extremely thin) cable connection with no apparent effect (unsure if this has to do with fact that the connection to the tiny device is MMCX).
Varying pin polarity - HM800 & 64 Audio IEMs
Then I tried increasing the volume and hey Presto the music surged into the IEM and the static died down, although it still persisted.
Similarly on the V30 & the iPad (although static was most pronounced on the latter). Dead silent/minimal static when no music playing.
Still trying out various file formats. Does not do DSF, DSD or generally 192 KHz or greater rez files - just puts out white noise. Also static levels seem to vary with different file resolutions.
Not entirely convinced it’s due to the sensitivity of my Noirs. Awaiting the arrival of the SONY MUC-M12BL2 3.5mm to MMCX plug cable I ordered to try out my Elex & other Focals as I don’t have any other IEMs on hand. Also trying out different USB C cables other than the supplied long but quite thin one.
First impressions:
