You are right......mine has been playing for 50 hours plus or minus and it is amazing.
Introducing Lotoo PAW GT2
- Thread starter audionewbi
Quadfather
I may just get rid of all my other DAPs. I am still deliberating...You are right......mine has been playing for 50 hours plus or minus and it is amazing.
I also have LP6 Ti. But I absolutely keep it
Quadfather
I really enjoy Sony NW-WM1Z with Shure SRH1540 headphones balanced. I am on the fence...I also have LP6 Ti. But I absolutely keep it![]()
Quadfather
How is it with Empyrean? GT2 is a dream with my Meze 109 Pro headphones.Today it arrived!
Alzberger
I have also the Elite, but I love the warm sound from the Empyrean I.
Quadfather
109 Pro is very good too.I have also the Elite, but I love the warm sound from the Empyrean I.
ecodr
- Feb 1, 2017
Would love to hear a review of the GT2 against the 320 Max Ti and LPGT Ti.
I have had LPGT and LPGT Ti. I can tell you that GT2 compared to LPGT Ti, it basically keeps the same neutrality and timbre. But in terms of amplification power, it is much much better. This translates into a touch more body and power on notes across the sound spectrum. Yet maintaining the same detail, speed and resolution. In the low range , you have a fuller sound. But the control (surprisingly) remains the same as in LPGT Ti. At the end of the GT2 break-in I realized that if at first I had thought GT2 had more body and (especially in the low end) this all seemed less neutral and less fast.....with the break-in instead it acquired again the same peculiarities as LPGT Ti but retained a more massive weight of notes. However, this increase in GT2's current passage allows it to make that qualitative leap and multifunctionality that LPGT Ti does not have. Let me explain.... When I used to put Rhapsodio V3 on Ti....listened well but even at or near maximum volume, I had the distinct perception that with amplification, Rhapsodio could give much much more. In fact I was looking at ported amps. With GT2 on the other hand , it is true that I have to turn up the volume a little bit more, but getting to 3/4 of it , Rhapsodio expresses itself considerably better, bringing out those qualities and quantity of sound that LPGT Ti just couldn't bring out because of a limitation in terms of current delivery. So GT2 brings this considerable advantage. Plus, assuming also that you don't need abundant amplification (as GT2 has), still GT2 compared to LPGT Ti, has a slightly fuller, slightly more full-bodied, more abundant sound WITHOUT ever losing anything at all in terms of neutrality, speed and naturalness. The only thing I have noticed in minor terms, (and here I ask for help from those who have had LPGT Ti before and now GT2) is that this greater amplification leads to the perfection of having a sound with the same spaciousness as LPGT Ti, but with sense of power more present , more impact. In conclusion I would say that GT2 sounds like LPGT Ti anabolized. Hoping I have explained myself well.....Would love to hear a review of the GT2 against the 320 Max Ti and LPGT Ti.
hAbIrAbI
- Aug 7, 2014
I just got my GT2 with the LTTP and just did a short functionality test. Since the LTTP seemed to drain the battery of my iPhone quite a bit I hope they will add a mode that allows you to remote control the GT2 to play local content from the SD card. That way the LTTP will only drain battery when you stream content to the GT2 or do some remote control action. Might need an app to perform such a task though.
Quadfather
Quadfather
Play it for a long time with several different sets of headphones. It is absolutely breathtaking once it opens up like a flower in the sun! It's just sounds beautiful.I guess I will be finding out soon enough.
Order placed!
Sounds excellent with both Traillii Ti and APX SE. Very pleasedPlay it for a long time with several different sets of headphones. It is absolutely breathtaking once it opens up like a flower in the sun! It's just sounds beautiful.
If it should jump into your mind to exchange Traillii TI for Traillii JP (+ money from me....) write to me anytimeSounds excellent with both Traillii Ti and APX SE. Very pleased
