apollo13
- Nov 30, 2016
Tank you very much!
Ok so here's a question for y'all...
My unit keeps freezing up if I select 'play the folder' from my root music folder and I need to use a pin in the reset button to get it working again.
Is this a known issue?
I'm using a Sandisk extreme Pro card, so I don't think that is the issue.
I've only had it for 24 hours, so it's quite possibly user error, I just can't work out what the issue is though.
I don't understand what you mean by play by folder.
You mean that in the root of your card you have various albums/singers in various folders right?
With this player you can select only by folder your music/files and there is no way to select by genres/artist etc.
Did you format your card on the player and if you haven't do it.
Also i will recommend to have only music in your folders without metadata or album art.I suppose that you are using the latest firmware right?
Do all this and let us know if you still get the same problem.
Not sure what may cause your problem but when i had my Paw Gold had no problems at all, but also never had metadata or anything similar into my files.
As i am used to the Tera Player,i keep my music clean.
Can you try with a folder without no metadata and see how it works?
Also if the problem persists i suggest emailing Lotoo China,they will provide you with a solution i am sure.
From where?
I would like to use the Vega, Andromeda, JH13 Frephase, Ibasso IT03, some Fads, Edition 8, HD800, Focal Utopia, the Abyss, and May be LCD4 if I can get my hands on one.
Where did you get it on discount in the UK?
There is no need to worry about where you bought it from, as all the units are the same.
Once I have obtained the latest firmware I'll let you know
http://www.hifiheadphones.co.uk/lotoo-paw-gold-portable-digital-reference-level-audio-player.html
Nice ,, will wait your feedback ,
for me , i will use it with my cans :LCD-X , TH-900 , Focal Elear , Emu Teak , AQ NightHawk , HE-400 , TH-X00 , IE800
Yes please ,, i cant find the latest firmware , my LPG will arrive next monday , i want to be ready
Just pm'd you mate
Thanks ,, and i hope you fix your problem ..
No problem. I've just emailed it to you.
We have @musicday
to thank, who sent it to me earlier
It happens when the lossless file is too compressed and the unit is doing more work to unpack and decode it.
