Now I’ve tried the EQ. I do see (and hear!) the point of the high shelf in taking the edge of the brightness. I do like the 6 dB slope, but cutting by -8 dB is just way too much.Try that and make sure to lower your digital output by -6db:
LSC 24 dB Fc 40 Hz Gain 3 dB
PK Fc 95 Hz Gain -4 dB Q 2
PK Fc 93 Hz Gain 2 dB Q 7
PK Fc 175 Hz Gain 2.5 dB Q 3
PK Fc 550 Hz Gain 1.5 dB Q 5
PK Fc 740 Hz Gain 2 dB Q 9
PK Fc 970 Hz Gain 1.5 dB Q 12
PK Fc 2000 Hz Gain 3 dB Q 3
PK Fc 2900 Hz Gain 6 dB Q 2
HSC 6 dB Fc 4000 Hz Gain -8 dB
Take good notes that the first and last filter are respectively a Low Shelf Filter with a 24 db slope and a High Shelf Filter with a 6db Slope.
Those are approximate but will bring you in the ballpark so you get a better idea of the Sonarwork rendering and if it is for you or not.
EDIT: I just made some correction.
This brings me to the bigger question: Why even buy the Ananda Nano in the first place if this is the tuning you’re after? Why not just go for something like the Sennheiser HD 600 which has a wonderful midrange but none of the technicalities of the Nano? That would get you much closer to what you seem to be after and at a much lower cost.
IMHO.
