zenki
@Ace Bee maybe you should compare sho dd to the 634ears.
pretty sure intime rules the treble imho
Old news, but this Sora Light midrange is just sublime. For a lack of better word, it sounds so "right" yet so not boring. The best part of it is that, with the vent mod, there is nothing that distracts me from this beautiful midrange, allowing for a louder volume. I use the filters that came with my Final Make4; they are sold by Final separately.
Covering the back vent with filters of various density. Denser = less bass, Taped-up = min bass, stock = max bass.How is the mod? Can you explain? Thanks in advance
Does anyone also experience a lot of driver flex on their pair of Sora Light 2019s? If so, is there a simple fix that involves ear tips and not opening up the shells? Love the overall sound but the flexing/crinkling adversely affects my enjoyment. I don’t have this issue with the Sora 2, which I assume is due to the presence of holes on the shells. Thanks.
The cracking/crackling is piercing. But yeah, you’re right though, I find that there has to be a break in the seal; creating an airtight seal attenuates and muffles the sound.Yeah, all the various Intime eaphones I've used suffer from driver flex. It's my one nitpick of the design, particularly how loud it is. The best way to prevent it is to keep the eartip from creating a full airtight seal. This can be accomplished using a smaller sized eartip or switching to foams. Sadly, doing anything like that will come at the cost of sound quality. When I did that the bass became anemic.
Can you provide some pics please?
Just want to clarify this mod. The graph shared above is my Sora light modded.How is the mod? Can you explain? Thanks in advance
The vent mod used here is when you create a vent under the tip. It basically creates a leak and reduces bass.
It's pretty cool but the problem is that I had channel imbalance because you can't make it exactly the same on both sides.
Thanks for the clarification. I had no idea the mod was intended to create a front vent, or that the graphed Sora belongs to you! I just tried creating a front vent like you did. I find that I don't quite like the feeling of not getting a seal. I also had trouble creating a front vent using my favorite Whirlwind eartips, as they are quite rigid.Just want to clarify this mod. The graph shared above is my Sora light modded.
Love this comment!I have the Sora. Yes it is dirt cheap and yes it sounds rather phenomenal, sharing my eartime with the almighty 64 U18 and my long-serving MH335DWSR lately. Very balanced and coherent with outrageous highs extension that's also smooth without too many peaks, kinda polite in the bass with average extension down low. Resolution in the level of mid-tier iems.
Giant killer is a term I don't like, and price is not a standard I'd like to use to judge things. I think no one would be disappointed with its SQ regardless of price. Taking in consideration also the techniques employed and the price of products with similar designs (but of lower performance level) as well as its pure Japanese heritage (only assembly is done in China) it would be a steal even at 5 to 6 times its price.
