sTaTIx
- Feb 12, 2002
I thought some of you might like this info. I emailed this one guy a couple of weeks ago, Michael Santucci, who's a sound professional at Sensaphonics, about the effects of high and low frequencies on one's ears and hearing damage associated with them. I stumbled onto a website on healthy hearing (http://www.sensaphonics.com/contact.html) which lead me to his email. I was looking for an answer to the question of whether it's the highs or lows that do most damage to the ears when heard at loud levels. Here's the response he gave me:
I was cleaning up my mailbox and found this, so I thought I'd mind as well post this here before I deleted it.
"That's a controversial question. It's true that the ear hears frequencies 3000Hz and 4000Hz (mid-highs) better than 125-250Hz (bass). In other words, it takes more actual sound pressure level (SPL) to hear bass at it's softest level than it does to hear mid-high frequencies at their softest level. When sound levels are measured through a sound level meter, theer are at least 2 scales to choose from -- A or C-weighted. The A-weighted scale reflects the way the ear hears at softest levels ( highs better than lows). Does that mean that at their loudest level, highs are more dangerous than lows? The Occupational Safety and Health Administration (OSHA) uses an A-weighted scale for measuring loudness levels in dB's (dB-A) to recommend safe doses of sound. Newer research suggests that at loud levels, the difference between the dB SPL for highs and lows are much closer than at the softest listening levels. This psycho-acoustic phenomena, called equal loudness contours, suggests that low frequencies should have more weight than the A-scale provides when listening at loud levels. "You should also take into consideration that most, if not all of the research is on military or industrial noise exposure, not musical, tonal exposure. In my audiology practice with musicians, I have used the A-weighted scale for in-ear monitor safety guidelines as well as for ER earplugs, because it is the legal criteria. My clients that follow the OSHA guidelines ( A-weighted) religiously don't show changes in their hearing." |
