BigSurSpoon
- Jan 4, 2007
I use the sendstation to my total bithead, but the sound quality is a little lackluster compared to the more expensive options. But it's good for the price.
Originally Posted by d-cee /img/forum/go_quote.gif may be just what you need http://www.qables.com/index.php?main...roducts_id=509 |
(Dumb question but...) Will you actually have audible differences between the 3.5mm to Dock Connector Audio Cable vs. the dual RCA's to Dock Connector Audio Cable? |
Originally Posted by jyxent /img/forum/go_quote.gif I've been looking at buying a portable amp for my iPod. I've mostly been looking at some starter amps, and I don't think I want to be spending more on a line out cable then on the amp. To fit my case, the dock connector cannot be any larger than the stock ipod connector. Is there any place I can find a line out dock with integrated 3.5mm plug for ~$20-30US? Or is the only option to try and make one myself? Thanks in advance, Jordan |
also, what makes these things expensive? ive seen some for as much as $100+...is it the quality? |
It is what people are willing to pay. There is some labor involved from the small companies. |
