IMR Audio : Sonic Adventures & Impressions
Future of IMR threads
  • Single thread for all models.
    Votes: 8 47.1%
  • Multiple threads for each model.
    Votes: 9 52.9%
  • Total voters
    17
  • Poll closed .
Dec 15, 2020 at 1:13 AM Post #991 of 18,105
Got stuck in the holder and tried to use a plier to take it out and ...... Don't think I will use the silver bass filter but am checking if Bob sells the filters separately.
Assuming identical diameters and threading, if you'd like to PM me an address, I can pop a replacement in the mail for you. I have 3 IMR "sets" and you are welcome to a silver Bass if you'd like.
Dec 15, 2020 at 1:48 AM Post #992 of 18,105
Thanks so much! I've PMed you.
Dec 15, 2020 at 2:33 AM Post #993 of 18,105
Dec 15, 2020 at 3:18 AM Post #995 of 18,105
Csn I ask what's the cable you are using? Seems to fit semper well.
It's from a HONG KONG local cable maker "Earzonehk", palladium plated gold+silver+copper, a rather heavy cable but surprisingly nice with the semper; and it feels a lot more comfortable for me than the stock cable, somehow the ear loop of the stock cable just don't sit quite well.
Dec 15, 2020 at 3:30 AM Post #996 of 18,105
I am using a cheaper graphene silver-plated copper cable which I find is quite a good match with the EDP and the Semper
I found Penon OSG amazing on Opus Mia, is an SPC with graphene but it isn't cheap, wich Graphene cable do you use?
Dec 15, 2020 at 3:34 AM Post #997 of 18,105
Material looks similar to Cema Tianwaitian and Penon Totem, did you test them?
Dec 15, 2020 at 3:37 AM Post #998 of 18,105
No i didn't. But i love this cable except it's a bit heavy.
Dec 15, 2020 at 4:33 AM Post #1,000 of 18,105
The eagle has landed and it is also a fat hen. :wink:
But very nice blue colour.
But lateral size is very similar (if not the same), therefore fit is still comfortable.
They are still cold from transport, so I give them time to warm up before I start "burn in".
Dec 15, 2020 at 4:50 AM Post #1,001 of 18,105
For the future, please remember.
Never use tools to assemble or disassemble the filters!
Dec 15, 2020 at 4:51 AM Post #1,002 of 18,105
@Daiyama you're Lucky, my PB2 is still on way... Bob said me PB2 is thicker.
Waiting for your listening feedback... where are you from? :wink:
Dec 15, 2020 at 4:56 AM Post #1,003 of 18,105
Quoted for truth. Use a rubber band for better grip.
Dec 15, 2020 at 5:08 AM Post #1,005 of 18,105
... and mine just arrived at my doorstep :robot:
Note: in the haste to unpack don’t throw the plastic film the Semper case comes in straight down the bin, as the 4.4mm cable is also inside, on the loose (as was stated earlier the case has no room to accomodate 3 cables).
