Kallbo
What cable is the standard for the Zenith ll? The black one? The copper one?
I haven’t tried cema cables with imr. But I’ll get 22awg copper cable ($80) next week.I was going to order Xinhs mix cable until I saw your comment. Which cables feom Xinhs and Cema have you tried ? And which one do you recommend ?
Thanks
This blue one?I haven’t tried cema cables with imr. But I’ll get 22awg copper cable ($80) next week.
As for Xinhs, I like their mix cable, blue one for about $50. It is a bit more v-shaped than stock imr, but overall fine without any weird accents.
Also, thick SPC white 4 core cable is not bad. It’s a bit thin on lower base, with smooth, slightly laid back mids and slight accent on treble.
Should be copperWhat cable is the standard for the Zenith ll? The black one? The copper one?
Lol, there are too much blue cables. I meant the blue 4 cores:
This sounds superb on the Ace the Album is brilliant live music captured perfectly
MARC COHN & THE BLIND BOYS OF ALABAMA: WORK TO DO
I suspect you'll find they shift significantly in the first 50 hours, they could go horrible around the 75 hour mark and climb to greatness 100 to 300. That been the story historically with the larger IMR DDs. The bass should settle down, mids come forward..... I wish you luck and patience!OOTB, not sure how I feel. Hmm, to say these are bassy would be an understatement. Very V-shaped signature with black/black filters. Blue/blue - same, but slightly less. Upper mids are quite recessed. Had to drop down to the purple lower and upper filters to tame the bass relative to the other frequencies and take the crispness of the treble down a notch. Treble is quite nice and crisp but not harsh. Drums have a nice snap to them. The piezo driver is certainly doing its job very well. It is absolutely the star of this show. Not sure I hear much effect from opening/closing the vents, maybe a slight reduction in bass, but I'm going to need to do some A/B after more burn-in.
All indications suggest that these need more hours for their signature to adjust, but there's nothing on the website for burn-in. I'm not stunned OOTB like I was with the ACE. The ACE was just at whole other level entirely. We'll see how the ZII develops over time.
