Zeppmeister
I think I'm also gonna pick up some of these? Couple questions? Have you tried most of the Azla Tips? If yes how do they compare? Which model did you get?
If anyone has good knowledge on these Spiral Dots which model would be recommended for increased bass performance?
I'm CONSTANTLY searching & buying Tips cause I have so much fit issues with ALL my monitor's! It's funny though cos i have ZERO issues with my TWS monitor's! I'm considering buying the Noble Audio Fokus Pro due to constant fit issues, the reviews of these are all phenomenal! So I'm really really hoping i don't get any fit problems with ACE?
Azla Xelastec: Great for a couple months, and then shape issues. If these were priced lower and/or lasted longer, these would have been first choice.
Azla SednaEarfit: Okay ... but something not quite right. Maybe the silicon is too firm? Comfort not quite there and, if I remember, the audio felt not quite right too. I probably should have tried the short, so as to bring the Elan shell close to the ear so the bone conduction could do what they're supposed to do.
