RumbleWeed
Never mind just got the emain! 46% really good actually!
Nope it is still the same spec with the Aten driver and 6mm ADLCWas just checking out the B.C and I'm sure someting is different? If I'm not mistaken the OG B.C had a 10mm CNT A.D.L.C and a 6mm CNT A.D.L.C?
Cos i can remember it had the same configuration as Dark Matter minus the Bone Conduction Motor?
Check your e-mail IMR peeps. Older legends are being reborn 20 items apiece.
@Poganin I haven’t received my ETS yet
Check out "promotions" section if you have gmailNo email for me. Not the first time either...
I was sure B.C came after he had stopped using the Aten driver and it was a 10mm & 6mm A.D.L.D drivers!Nope it is still the same spec with the Aten driver and 6mm ADLC
Have the bc and can corroborate, its aten 5 + 6mm ADLCWas just checking out the B.C and I'm sure someting is different? If I'm not mistaken the OG B.C had a 10mm CNT A.D.L.C and a 6mm CNT A.D.L.C?
Nevertheless they still sound amazing. Right now I'm using my rah and man... This soundstage...You must know/learn this if you deal with IMR:
Words like: special
limited to xx
exclusive
has not the same meaning as you are used to. He uses them a little bit more „flexible“…….
Will he release such an IEM?Actually haven’t talk a lot about this but I got a prototype bob made, aten5 driver + 2 6mm ADLC
Mids are a fit more 3d and aggressive, though it needs good amplification for it to truly shine
Utilising the 5th Gen Aten driver combined with the new A.D.L.C (amorphous diamond like carbon) driver provides a bass heads dream IEM.Was just checking out the B.C and I'm sure someting is different? If I'm not mistaken the OG B.C had a 10mm CNT A.D.L.C and a 6mm CNT A.D.L.C?
Check your emails from todayDoes anyone know how loyalty discount's are being done with these new classic's?
