The only thing from the package I really dislike is the cable, pretty stiff and with earhooks.
So I couldn't resist and modded the socket of my favorite budget cable, Eagle 16, to fit the Ozar.
The connector diameter and colour fits the Ozar perfectly, looks like it came like this from factory
One thing I never shared so far and never seen it anywhere before, which improves the fit and sound compared to stock silicone tips:
My modified foams
Don't look pretty, but work very well.
The backstory: I always loved the fit, bassy sound and isolation of foams, but hated the muffled highs. I discovered, that inside of the tip there is a plastic tube, which is shorter then the foam itself. This excess foam on top of the tube muffles the highs. Cutting that foam down to the plastic tube eliminated the muffling. Now the fit, isolation AND highs are amazing
