IMR ACOUSTICS - EDP+ (A.D.L.C / CNT / Planar)
1st impressions
(foam tips / 4.4mm stock cable / Sony WMA)
THE GOOD:
NEW! cable - very nice - Tight fit - the shells will not be falling off!
The return of the extra small hard case
Fit - fine for me btu I use foams so they always hold everything in place
The Sound - Elegant, Noble, smooth, creamy detailed, excellent separation and clarity of instruments, Divine sub bass, Reference sounding in terms of balance
THE BAD:
Its clear that they are going to need a LOT of burn in. You can kind of hear the tightness and rigidity of the drivers holding things back...to be expected though
There is an occasional biting harshness to the mids, especially on some vocals BUT I think this is just your classic out-of-the-box thing and will smooth out later, especially giving the overall smooth details that over ride everything
(Its not THAT bad - dont worry - I just mean in comparison to how excellent ALL the other aspects of the entire frequency range!)
I think these will end up being more on the side on reference tuning than bass monsters but i think the creamy detailed warmth will be so delightful this wont be an issue...at all
The shell may be a bit to big for some?
CONCLUSION: - VERY much looking forward to hearing these after 200+ hours. The potential seems to be a beautifully detailed, NATURAL, warm REFERENCE sounding long listening classic. Very 'friendly' sounding
There is so much potential you can hear with these - Im very happy with them
A couple fo pics - compared to Opus Mia (Opus in the right) :
