Rico67
- Dec 28, 2007
I have finaly discover than i can listen high definition audio with my Imod by using Rockbox.
So I have test it with 24 bit 96 Khz files and all is perfect in different format 'ALAc-AIFF-Wave.
But it seems than DVD audio have a "magical protection to avoid rip".
So i use DVD fab first to make a clean copy without protection from my audio dv, and then use DvdAexplorer to rip the file in an audio forma (wave).
It seems ok, but some files keep there protection.
Have you another way to process ?
Thanks.
Thanks.
