iFi Zen Stream: Setup, Tips, Tricks...
Aug 7, 2023 at 10:34 AM Post #1,276 of 2,082
Aug 7, 2023 at 10:35 AM Post #1,277 of 2,082
so ifi sent me the firmware software to unbrick my stream. now its working perfect. Yhank you ifi!!
i use Mconnect with the stream. i have my qobuz and tidal in the app and it sees what ever is hooked up to the stream. so Ifi really doesnt need to. develope more software. plus their ifi local works pretty good with a drive i found. just my 2 cents point of view.
what really made my stream sound amazing was a SBooster power supply.
Glad you are up and running again!
Keep us updated!
Cheers!!
Aug 7, 2023 at 5:01 PM Post #1,278 of 2,082
Hi! Running Tidal Connect on ZEN Stream (2.31.7) via ethernet 1Gb/s from updated Tidal App (HIFI+) on iPhone 14 Pro to Rockna Wavelight DAC on USB connection. New Tidal functionality was released a few days ago with FLAC (Max) support in stead of MQA (Master). This test album should give 192kHz out from ZS, but I "only" get 96kHz for some reason, Everything is set to max resolution and the DAC supports 384kHz over USB. Strange. This is the album I am testing on: https://tidal.com/browse/album/175019081
Do you see the same problem?
Cheers!
Aug 7, 2023 at 5:11 PM Post #1,279 of 2,082
Cheers!
Tidal had not yet converted everything to HiRez FLAC only about 6 million I thought was the number. So there will be a mix of MQA and FLAC for awhile.
Also I have seen many instance of there being multiple versions off an album on Tidal with no way to select them.
I will check this for you as soon as I can to see what I can find out, perhaps someone with Roon could check it before me.
Cheers!!
Aug 8, 2023 at 7:52 AM Post #1,281 of 2,082
Here are the results of what I found...
As you can see by this screenshot Roon, Tidal and Qobuz both have several versions of this Album
How you choose which one using the Tidal app itself I do not know.
Here is the Tidal app using Tidal Connect playing to my ZEN Stream and into my SMSL DAC
As you can see the resolution in the app is set to "MAX" (new settings), and here is the resulting pic of this
So if your DAC is only indicating 96 khz I would suggest talking with them, or you have something wrong in your settings. As you can see there is a green light indicating MQA and my DAC reports 192khz, if your DAC does not support MQA I would suspect that is why you are seeing 96 as this album as of yet has not been converted, on 44.1 available in FLAC.
Hope this helps...
Cheers!!
Aug 8, 2023 at 9:51 AM Post #1,282 of 2,082
Same here! Having run into connectivity issues a few days ago I opened a ticket on Friday and received instruction on Monday. The instruction appeared time consuming to say the least but it went ever so smooth. Big up iFi. Ofcourse sound also improved a lot :laughing:
Aug 8, 2023 at 10:13 AM Post #1,283 of 2,082
Awesome! I will pass along your comments!!
Cheers!!
Aug 8, 2023 at 11:03 AM Post #1,284 of 2,082
Hope this helps...
Cheers!!
Aha! This explains it!! Thanks!! :-) My DAC does not include MQA, so thats why as you say!
Quite irritating that you can not see in Tidal if it is FLAC or MQA hires tracks that are playing.
I took it for granted that this was FLAC, since Tidal has converted from MQA to FLAC on hires and marked these tracks as Max and not Master.
Bad assumption... Again thanks for the effort to shed light on this!
Aug 9, 2023 at 2:35 PM Post #1,285 of 2,082
Hi, i am using the ifi stream with external usb ssd disk. On the "Artist" and "Albums" sections the ifi stream app won't show albums of wav files, only flac albums are shown.
I can see and play the wav albums in "Music Library" section but thats too much browsing.
Now at the scaning option i can see how many albums were found so i know that it aware of the wav albums but still won't show them.
Any idia ? Tnx
Aug 10, 2023 at 9:05 AM Post #1,286 of 2,082
Any idia ? Tnx
I would think it is possibly related to a "tagging" difference between the way the WAV files and FLAC files are tagged, but I do not know for sure.
I would put up a ticket to support to see if they perhaps know off-hand. Of course, others may chime in and shed some light as well.
https://support.ifi-audio.com/
Cheers!!
Aug 10, 2023 at 9:10 AM Post #1,287 of 2,082
Cheers!!
You right. I didn't had this problem with roon, bluesound and jriver but i guess that ifi stream work in a different way.
What i did is i converted all the wav files to aiff
Aug 10, 2023 at 9:41 AM Post #1,288 of 2,082
I could never get this to work reliably. Every time I switched the unit on I would have to go through a ritual. Sometimes it would find all the files, but more often than not, many were missing. This was using a 1TB SSD.
I had better luck storing the files on SD card in phone or tablet, and using DNLA & Bubble....but I wasn't keen on the bubble interface.
I did solve the issue using a radical approach :relieved:
